  • Guests: 83
01/12 RoV IW3IPD (63)
Feedback antenna sparking and 1N60 diode burn
hsieh
Wed Jan 26 2011, 09:36AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
Sometimes I found my feedback antenna is sparking and when I use a higher input voltage (50V) today after a short run diode D2 Link2 burned and produced some orange light.Why?
And how can I tune class E SSTC?should I connect oscilloscope to my SSTC?Or just change diffrent caps trying to get longest spark?
My frequency is 450KHZ,what cap value should I try?
Thanks
axelro
Wed Jan 26 2011, 08:08PM
axelro Registered Member #3640 Joined: Sat Jan 22 2011, 12:16PM
Are this germanium diodes? Then they probably are just a tick sensible - or your feedback antenna is too close. Try using 1N4148 or move to a bigger distance.
Real class E is not this simple - check either Steve Wards or Richie Burnett's web page, there are good examples and explanations. In particular see Steve's notes on coupling.
Gregory
Wed Jan 26 2011, 08:09PM
To tune it you need an oscilloscope, and the capacitor need to be calculated using as reference your primary inductance. Read this to understand better what is and how works a Class E system: Link2
