  • Guests: 36
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
My First time with ZVS FBT Driver
LUGIA
Mon Jan 24 2011, 01:21PM Print
LUGIA Registered Member #1706 Joined: Sat Sept 20 2008, 05:41PM
Hi everyone
let me show my first ZVS Flyback Driver (First time with HV)
M
OUT SIDE. Look good?? and then inside (I screen name LUGIA because in thai web i have change name to lugia)
M
M
M
testing
M
and result
M
M
M
M
M
Circuit from 4HV Wiki ZVS Flyback Driver original version. I run it at 12Vdc from PSU Computer it draw current not much i see peak's 5.2A usually's 2.5-3.7A (Idle/No load is 0.6-0.7A) but give a lot of power. Primary 10Turn Center Tap no modified. Here is my video sorry for low quality i record by crappy phone
Turkey9
Mon Jan 24 2011, 08:35PM
Great construction for your first HV project! Any chance we can get an overall shot of the internals? Any pictures of the arcs?
LUGIA
Wed Jan 26 2011, 01:48AM
Thank you for comment here's arc
M
M
Inducktion
Thu Jan 27 2011, 12:52AM
Ooo. Nice arcs. I recently built a ZVS driver too. I can't tell what's wrong with it but the arc's are insanely noisey and annoying. I think i need a better PSU.
LUGIA
Fri Jan 28 2011, 04:46PM
Inducktion wrote ...
what's your psu v and a I use a Computer PSU (Bestec) 350W 80p
Inducktion
Tue Feb 08 2011, 09:32PM
I managed to fix it, and works sooo much better. The issue was the inductor, it was a ferrite toroid, and i switched it out with an iron powder one. After that i rebuilt it again, this time much more neater, and using IGBT's. I recommend using IGBT's over mosfets in ZVS's because they seem to push alot more power through the flyback with alot less heating than fets. Using my IGBT ZVS driver, i pushed 40 volts DC into it, at 11 amps current draw. The arcs were pretty amazing and hot!
