  • Guests: 39
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Mystery Photos from TDU
Sat Jul 29 2006, 03:09PM
It's 2 rings interacting and a third in the back ground. It looks like a wide thin ring (slow moving) being warped by a fast movign fat ring. Have you gotten them to wobble yet? If you do they will occilate pretty quickly untill they hit something or dissipate.
Tesladownunder
Fri Aug 18 2006, 12:17AM
Here's another.
Peter
1155860271 10 FT10696 Mysteryphoto29
Electroholic
Fri Aug 18 2006, 01:42AM
im guessing an argon laser
looks like some kind of cave.
but i guess that the weird shadows are reflections off some trees.
Alessandro
Fri Aug 18 2006, 07:09AM
Alessandro Registered Member #70 Joined: Thu Feb 09 2006, 08:19AM
Laser "tunnel" effect with an agron laser. Looks like it was outdoors because the fog didn't fill the entire picture.
Tesladownunder
Fri Aug 18 2006, 05:32PM
Alessandro wrote ...
Correct and here are a couple of other shots.
This is one of my better displays. The effect is surreal with the swirling smoke patterns that form the tunnel. It takes up your complete field of vision and gives no external point of reference. It is particularly breathtaking when the tunnel slowly closes in on you and you disappear in a quantum singularity. Fortunately I reformed in a parallel universe shortly after.....
Peter
1155922374 10 FT10696 Laserlissajousargonwormhole
1155922374 10 FT10696 Laserlissajousargoncosmic
Avalanche
Tue Aug 29 2006, 05:04PM
Here's a mystery photo from the avalanche if no one minds cheesey
shouldn't be too hard to get this one.
1156871071 103 FT10696 Mystery
Tue Aug 29 2006, 06:26PM
Interwoving a bunch of litz wires together with a drill..?
Avalanche
Tue Aug 29 2006, 10:56PM
You got it tongue
I was making the wire for the secondary of my inverter transformer. There was 13 meters there, attached at the other end to a hook right inside the house cheesey
Tesladownunder
Fri Sept 01 2006, 06:44PM
Another photo I took tonight.
Peter
1157136290 10 FT10696 Mystery 24
Avalanche
Sat Sept 02 2006, 05:25PM
Driving past street lamps with a long exposure? I dunno cheesey
