  • Guests: 52
J. Aaron Holmes (50)
Lukasz Sterczewski (36)
Coileone (40)
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
Mystery Photos from TDU
Thu Jun 29 2006, 07:56PM
the first one looks like a piece of sch80 pvc pipe with a film of blue pvc solvent weld glue across another piece inside it.
The second is a long exposure of a red HeNe and some blue LEDs... The HeHe is being relected off a speaker onto a moving screen. The leds were dragged throught the exposure.
shades
Tesladownunder
Fri Jun 30 2006, 12:33AM
WRONG (it was schedule 40) wink Well OK you were sorta right...
Yes it was a 4 inch TC secondary. The end cap was a little oversized so extra lake of PVC solvent. The irregular outside rim was masking tape to hold the wire end.
Second photo is half right. It is a diode laser (not HeNe) on a long exposure. The blue lights are 4 LCD screens of a power supply. Any other suggestions as to how the pattern was made rather than a speaker?
Peter
Fri Jun 30 2006, 12:52AM
No fair adding tape arround the pipe to confuse me on the wall thickness cheesey
I thought the red seemed a little too dark to be your hene, you almost had me thinking the blue was your argon, but I decided that that was just too blue.
As to the pattern... It is much to regular to have been moved by hand... And the camera couldn't have been moving that much since the blue is pretty much strait... And I doubt that you found a way to move the background to make that pattern... Were you shining it off a spinning mirror at some weird angle?
benbradley
Fri Jun 30 2006, 04:01AM
benbradley Registered Member #312 Joined: Mon Mar 13 2006, 01:50AM
... wrote ...
kind of amazing... That whole bag of ferrite beads, the whole lot of them after being wired up into a module costing soo much, is like 5% of a floppy disk amazed
THe same seller now has an auction for 200 milllion cores (!!!), so now you CAN build that floppy disk emulator!
wrote ...
i just gutted a SMPS, and I found some slightly larger ferrite beads (2mm OD) on the leads of some dual diode. see if i can get some pix later...
what are they for?
2mm appears to be over twice the diameter of mine, though earlier core memory may have used even larger cores.
But for a SMPS or most applications where a bead goes around a component lead, it's meant as a lossy inductor, to reduce the RF interference generated by the fast switching of the diode. I believe it's a somewhat different kind of material, still magnetic but with different properties than that used for core memory. If you google ferrite core and powdered-iron core you can find descriptions of materials used for various types of inductors and transformers.
Tesladownunder
Fri Jun 30 2006, 10:23AM
... wrote ...
The beam from a 5mW red diode laser is reflected by a mirrror on an instrument recorder amplifier that I found while dumpster diving at the physics Dept. This would normally drive a pen on a moving roll of paper (like a seismograph). It is 1981 vintage and has offset, gain and calibration controls. Full scale deflection seems to be about 0.1V and frequency response seems to go up to about 70Hz. Sadly I didnt pick up the second one.
The unit is fed from my frequency generator at about 70Hz and the result is a horizontal stripe. The circular motion is simply me rotating the camera by hand with a 1 second exposure. This brings out the sine wave character and also shows some additional sine wave superimposed on it.
The next mystery photo is at the bottom.
Peter
1151663028 10 FT10696 Laserlissajousrecorder
1151663028 10 FT10696 Laserlissajoussetup
1151663029 10 FT10696 Laserlissajoussetupverticalsweep
1151663029 10 FT10696 Mystery 22
Tesladownunder
Sun Jul 02 2006, 03:15AM
Next Mystery photo.
You should all recognise the trees in my back yard by now.
Peter
1151810157 10 FT10696 Mysteryphoto22
Sun Jul 02 2006, 03:21AM
Eucalyptus
Tesladownunder
Sun Jul 02 2006, 04:23AM
"Ahh.. you have much to learn little grasshopper"
(Mr. Miyagi to Daniel-san in Karate Kid )
Methinks you see not the wood from the trees... (me)
Yes they are eucalyptus and some peppermint. Is that all there is of interest?
Peter
Sun Jul 02 2006, 04:58AM
Well there is that red thing in the trees... That is new wink Looks like a personal flotation device to me tongue
The bark on that pic and on the one of you in front of the exploding cap bank looks just like the ones in my back yard... Maybe you got some of the American diseased ones?
Tesladownunder
Sat Jul 29 2006, 08:00AM
The mystery red object was a can being shot 15 feet out of my latest can crusher. It was positioned so that the base was level with the center of the work coil so it will fire the coil in the air. The can is shortened however as shown in the photo.
Next mystery photo is a bit easy but a full explanation is needed.
Peter
1154160035 10 FT10696 Cancrushuniairborne15ft
1154160035 10 FT10696 Cancrushuniairbornecansclose
1154160035 10 FT10696 Mystery23
