  • Guests: 84
VTTC power supply substitution?
hsieh
Sun Jan 23 2011, 08:28AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I want to build a VTTC but I can't find MOTs.Is there any alternative?
Can I use a ZVS driven transformer or voltage multipler to power my VTTC?
thanks
Dr. ISOTOP
Sun Jan 23 2011, 09:28AM
What transformers do you have access to?
I think flybacks provide too much voltage, and you're not going to be able to make a mains voltage multiplier that can provide that much current easily.
william L
Sun Jan 23 2011, 10:17AM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
perhaps if you wound like 50 turns of wire for a zvs, as that would lower the voltage.
(zvs operates outside of flyback operation, right?)
hsieh
Sun Jan 23 2011, 12:23PM
bwang wrote ...
I can find various kinds of ferrite core and bobbin and I have access to coil winding machines.So I can wind any ferrite core transformer.
Sun Jan 23 2011, 04:26PM
You must first choose the thermionic valve you are going to use, and only then can you work out what power supply will be needed.
No TV or monitor-type LOPT ('flyback') will be suitable for supplying popular VTTC designs using power valves like 811.
An alternative to MOTs is to use actual valve PSU transformers but these are usually expensive, not always easy to find, and are costly to transport because of their weight. Parmeko oil-filled transformers are the gold standard against which the quality of all other transformers may be measured.
RayeR
Fri Jan 28 2011, 12:08AM
RayeR Registered Member #333 Joined: Mon Mar 20 2006, 06:02PM
You can build cascade voltage multiplier utilizing some line filter elyt. caps from old CRT monitor/TV - e.g. 100uF/400V. I belive you can get about 1kV with reasonable current for VTTC. But I can't belive you cannot find any MOT, try to find some local rubbish collecting and recycling yard...
Gregory
Fri Jan 28 2011, 04:27PM
Is better a MOT, for a normal VTTC operation and the sword spark effect you need the AC half-rectified voltage envelope!
Nah
Fri Jan 28 2011, 08:13PM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
You could try using old tv transformers in a voltage doubler, that would give you around 1600 volts at 400-600 watts. Try using 2-4 of them
Gregory
Sun Jan 30 2011, 03:21AM
Yeah, but the coil will work in CW mode.. This isn't what the tubes want!
