  • Guests: 55
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
Big Li-Poly Battery Packs
Electroholic
Sun Jan 23 2011, 03:48PM
What kind of voltage, Ah and C rate are you looking at?
For pouch type cells, i think Kokam is still the best, if not expensive. 18650 cells might be easier to manage thermally if you are looking into high C rate.
5.5kWhr at 132V norminal
BEGtc
Adam Munich
Sun Jan 23 2011, 04:15PM
Yep hobbyking has good stuff. PS: This is an amazing controller if you ever need one. Link2
It used to only cost $15. :-/
Sun Jan 23 2011, 05:12PM
Electroholic, I'm looking at 3 individual packs, 3 cells each, 5-6AH per pack, maximum discharge current of about 3-3.5A in bursts, with an average of less than 1.5A. Basically, I'm going to shove as much capacity as I can into 1kg.
I'd like to charge them fairly rapidly though, around .75C give or take, if at all possible. The protection circuit I have my eye on right now is also a charge controller, but can only swing about 1.3A max charging current. That's a bit on the low side, but having the charger complete with cell balancing built right in probably makes it worth the trade-off.
-Dave
rp181
Sun Jan 23 2011, 06:51PM
dont skimp on a charger, it could end badly. Don't even think of buying a charger from hobbyking!
Electroholic
Mon Jan 24 2011, 05:58PM
5 or 6AH RC packs should still be readily available from RC stores. And if you are not cycling at high C-rate, the useful life is more dependent upon the storage condition and manufacturing quality. What BMS are you looking at, can you bypass the charge controller but leave the balancing circuit functional and use an additional RC type charger?
Ken M.
Tue Jan 25 2011, 06:07AM
I if he gets a good charger or has a good charger, I don't think it will let him charge with out a balance, at least mine doesn't but then again I splurged on a $250 charger, a bit over kill but it is a Hyperion which are said to be one of the best, and I liked it because I could charge up to a 12s battery pack, as well as claiming to handle 100W per charge port (de-rated from 180W).
ConKbot of Doom
Tue Jan 25 2011, 05:32PM
At work we've had luck with batteryspace lipo batteries, big 29.6v, 10AH packs feeding some vicor dc-dc converters for portable power for various equipment. A lot of their larger ones have built in balancing, which is nice, so even charging with a CC/CV power supply, or only somewhat smart charger is fine. Check out the next catagory up from the one I linked too, they have higher capacity Li-ion and Li-po packs.
