  • Guests: 41
Electrical Quizzes - QUIZ 8 POSTED
Thu Feb 23 2006, 06:53PM
We only consider positive cycle. Capacitive reactance is about 1/.314 ohms
Current peak is 69A
Current RMS is about 49A if this was a full sinusoidal; however, half of cycle is zero
Therefore current is average of 49 and zero which is about 24A
Now, we add the load of 5A on parallel limb to get about 29A current read on meter.
Thu Feb 23 2006, 09:30PM
IamSmooth wrote ...
So without the 5A load the meter wil read 24Arms? suprised It should read zero.
My theory is that input power=power to load: The power on the load is 5*Uout watts. The peak mains input voltage is Uout/2. Because charging of the capacitors only occurs at the peaks, the RMS input current is 10A (at half volts=same power). This divides into two half-waves, but the meter reads only one, so it will read 5A RMS.
Fri Feb 24 2006, 12:41AM
+2.5A top (read by meter)
Fri Feb 24 2006, 11:03AM
jmartis has the right answer, but for the wrong reason, so he only gets half a cookie confused Hint: Moving coil meters do NOT read RMS (you must know this if you solved quiz 1)
WaveRider
Fri Feb 24 2006, 11:56AM
Moving coil meters measure average current...
Do I get the other half of the cookie? cheesey
Fri Feb 24 2006, 12:47PM
Yes, you can have the other half shades
The argument I used to figure this out was:
*Moving coil meters read average current
*Capacitors block DC and pass AC. DC is the same thing as average. Therefore, C1 passes no current on average, just an alternating ripple current.
*Therefore the average current in the two meters must be the same: 5A
Fri Feb 24 2006, 12:59PM
wrote ...
Actually, I get the other half of cookie.
Jmartis stated the meter would read 5A RMS. He was half-right in that the meter would read 5A, but wrong that it would read RMS. Its really 5A AVG.
I stated the meter would read 15A RMS. Which is actually the CORRECT answer should the meter have read in RMS, however the meter reads in AVG. cheesey
QUIZ 7
Okay, time for something tougher . . .
Assume the following:
a. Vin(initial) = 0.010V
b. No offset voltage
c. operational amplifier is stable at unity gain closed loop
d. assume BJT beta is very large
QUESTION: If the input voltage is increase to 0.010V (factor of 10), how much does Vout change? (need an actual number, not an equation) You must provide the reason too or you get no credit.
WaveRider
Fri Feb 24 2006, 01:28PM
It is a logarithmic amplifier. increasing the input voltage 10 times increases the output voltage ln(10) times. This is because the emitter current is exponentially dependent on Vbe...and since the transistor beta is very high, collector current very nearly equals emitter current... Assuming "infinite" amplifier gain and op-amp input resistance, the output voltage will be
Vo = -Vt * ln(Vin / (R * Io))..
or thereabouts.. Vt is the thermal equivalent voltage (about 0.026V) and Io is the reverse saturation current.(around 1e-14A).
All this assumes that the transistor is in the forward operating region..
Fri Feb 24 2006, 01:49PM
Sorry EV, no half cookie for you! The relationship between average and RMS is a complex one that depends on a bunch of things, like conduction angle of the diodes, supply inductance, etc. If it works out as "3" then it's by sheer luck :P
Your log amp would be unstable even if the op-amp was unity-gain stable, due to the extra loop gain added by the transistor. So I'll guess Vout will be about 20V of high frequency crud.
Fri Feb 24 2006, 01:57PM
Steve Conner wrote ...
Sorry Steve. Do the math, or even do the simulation. The RMS current is indeed 15A. I did this first by calculation, and then verified it with PSPICE. I'll even build the circuit up in the lab to prove this. So give me my damn cookie! I want a whole one now! amazed
1140789455 15 FT1067 Waveform01
