  • Guests: 54
Electrical Quizzes - QUIZ 8 POSTED
Wed Feb 22 2006, 03:38PM
Congratulations, solution is right.
I had to decode the schematic a bit, but it seems good.
I solved same problem a bit different;
1140448666 T
But result is the same. smile
Wed Feb 22 2006, 07:48PM
QUIZ 6
1. What is the quiescent current when the circuit is off?
2. After 60 minutes of being in an engineering lab, what is the state of the circuit?
Tetrafluoroethane
Wed Feb 22 2006, 08:51PM
Tetrafluoroethane Registered Member #127 Joined: Fri Feb 10 2006, 03:36PM
Answer 1) 3ma?
Answer 2) Disconnected from power because someone hit the button after 5 minutes and nobody could find any other way to shut it off.
Electroholic
Wed Feb 22 2006, 08:55PM
do we assume the transistors to be perfect?
no leakage?
Wed Feb 22 2006, 10:50PM
Is the quiescent current zero?
Hazmatt_(The Underdog)
Thu Feb 23 2006, 12:22AM
You guys are using up way too much thinking power to come to the answer!
I agree with the relay, Flip Flop or transistor inverter circuit.
>>>>HEH...woops..I was still reading page 1<<<<<<<<
WaveRider
Thu Feb 23 2006, 08:36AM
Quiescent state current: very nearly zero (just leakage current thru transistors).
State after an hour in the lab: Disconnected from power (as TetraFluoroEthane said) because no one can turn it off! (The transistor configuration is like that of an SCR.)
Cheers!
Thu Feb 23 2006, 12:37PM
I guess EV's last quiz is solved, so here is one.
The circuit below is a voltage doubling rectifier, loaded by some sort of load (you don't need to know what) that draws a steady 5 amps DC with negligible ripple. The moving coil meter I2 will obviously read 5 amps. But what does the other meter (I3) read?
Thu Feb 23 2006, 01:00PM
wrote ...
Yes, congratulations goes to Waverider - Nice job!!!
wrote ...
The current through I3 will be postive spikes of high current at a frequency of 50Hz, but since I3 is a coil vane meter, it won't be able to react fast enough to detect these, so instead it will read the Rms current of this which is approximately 15A.
Dan
Thu Feb 23 2006, 05:08PM
I3 will read also 5 amps.
