  • Guests: 28
Wizzup (30)
12/09 Killa-X (34)
12/09 Luca (45)
12/10 davovinch (75)
My first SSTC
hsieh
Tue Jan 18 2011, 02:35PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
This is my first SSTC.It's based on steve's MicroSSTC.
It's powered by 20V AC(full wave rectified)
But I have problem installing a topload.After I install a topload, spark disappeared,power transformer overload and I was shocked by the metal casing of my oscilloscope.
I also don't know how to install a discharge point.The temperature can melt copper,needless to say any nearby plastic.Of course I can't use metal.Maybe I should try glass?
1295361312 1412 FT0 Dscn7977
1295361312 1412 FT0 Dscn7976
Tue Jan 18 2011, 03:57PM
謝昕哲 wrote ...
Hey
Your single MOSFET power stage is simply too weak to drive a coil with a topload when it is also only powered by 20VAC, you will properly need a larger heat sink on the MOSFET if you will up the voltage enough for some more serious sparks.. Did you even have a breakout point on the topload?
What BPS are you running at? The interupter frequency..
A piece of solid 1.5mm^2 copper wire should do fine as breakout point, just make sure its needle point in the breakout end... Makes it about 10 cm long, should be long enough for it to dissipate some heat before melting what you secured it to, toploads of metal will absorb some heat too.
hsieh
Wed Jan 19 2011, 12:41AM
Mads Barnkob wrote ...
Hey
It's running CW.No interupter.
I tried to use a small piece of copper lead as a breakout point. But I still can't see any spark.
I also want to know why I get electric shock when I touch the metal casing of my PC PSU(I once powered my coil with it) and my oscilloscope after I install a topload.
Matt Edwards
Wed Jan 19 2011, 05:57AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Not bad dude. My first coil was similar
Ken M.
Wed Jan 19 2011, 07:14AM
Well your PC PSU and your o-scope is grounded correct, if so and your ground for the TC is tied to that same ground, it just means that you are acting like a capacitor and storing some of the energy given off by the TC, then you discharge to the nearest grounded item.
