  • Guests: 34
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
BIG voltage regulator?
Dr. ISOTOP
Tue Jan 18 2011, 09:44AM Print
Are there any voltage regulators that can supply very high current? The largest ones I've found are the LM338 (5A) and the LT1577 (10A). Ideally I'd like to get 30A off a single regulator, saving me the hassle of paralleling multiple LM338's.
This is for driving high-power laser diodes, so the output voltage only needs to be about 3V.
cedric
Tue Jan 18 2011, 10:03AM
cedric Registered Member #2941 Joined: Fri Jun 25 2010, 08:08AM
dc-dc converter
ScotchTapeLord
Tue Jan 18 2011, 01:57PM
Laser diodes should use a constant current supply like a continuous mode buck step-down converter or something of the like. If you can find a well-regulated DC supply and don't care about efficiency you could use a resistive divider to get the voltage you want, and the fixed nature of the resistors will also help limit the current (though not as reliably as a proper ccps).
Mattski
Tue Jan 18 2011, 06:53PM
The usual method of increasing the current capacity of a linear regulator is to use an external pass transistor with a voltage regulator chip. Check the application notes of common regulators like LM78xx regulators, they should have example circuits for this. Then you just need to buy a transistor which can handle 30A and the power dissipation, or there are ways to parallel these transistors usually with series resistors to improve current sharing.
Find an example in this datasheet page 13.
Tue Jan 18 2011, 09:08PM
Mattski wrote ...
I agree, and what a nice datasheet. They even have a schematic for a short circuit protection transistor.
Tue Jan 18 2011, 10:55PM
You can also find linear voltage regulator controllers that drive the gate of an external pass transistor, and include protection features. I recently designed-in a Maxim MAX8564 (in tiny "uMAX" package) driving a Fairchild FDD8586 35 amp MOSFET.
Wed Jan 19 2011, 09:27AM
What ScotchTapeLord said. You can't power any luminescent diode with a voltage supply...
Electroholic
Wed Jan 19 2011, 10:14AM
maybe this thread will help
Daedronus
Wed Jan 19 2011, 08:02PM
On eBay search for "ems power supply"
It's the simplest solution I can think of for powering this laser diodes....also worked for me.
teravolt
Wed Jan 19 2011, 08:36PM
hi bwang what they are taking about is a emitter follower and here is a site that has a description and scematic
