  • Guests: 84
A thought on the classic vttc
Nah
Fri Jan 14 2011, 10:21PM Print
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
Take the classic vttc.
Now the tickler coiler is used to tell the tube when to turn on and off. It is also a bitch to tune, depending on the primary coil, voltage, EM fields, etc ; not fun.
Now what if instead of using a coil, you used a vari-oscillator? You could control the volts, the hz, the amps, and do all sorts of things. You could even use it to modulate the screen grid.
Anyone see any flaws in this?
ubuntupokemoninc
Fri Jan 14 2011, 10:44PM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
I had this idea along time ago basically a sstc only using a tube instead of a transistor.
quicksilver
Fri Jan 14 2011, 11:10PM
Just a speculation; but wouldn't that be damn hard on the tube(s)?
Dr. Drone
Fri Jan 14 2011, 11:45PM
shades
