  • Guests: 71
My 500KV Marx Generator
Oneironaut
Fri Jan 14 2011, 10:09PM Print
Oneironaut Registered Member #3616 Joined: Fri Jan 14 2011, 08:47PM
This was one of the more dangerous (fun) projects I built to test the ability of high voltage to disaggregate a rock sample...
Cheers!
Brad
ubuntupokemoninc
Fri Jan 14 2011, 10:24PM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
Can I see a video?
Oneironaut
Fri Jan 14 2011, 10:39PM
Yes, at the end of the 18 page build log, there is a video of it smashing up drill cores.
Brad
Dr. ISOTOP
Fri Jan 14 2011, 10:46PM
Specs of the generator?
Things like stage capacitance, inductance of the inductors, etc.
That is one awesome beast!
Adam Munich
Fri Jan 14 2011, 10:47PM
Nice site, but you should make a show all pages button. It's kind of a PITA to keep pressing "next page".
Plasmana
Fri Jan 14 2011, 10:55PM
Plasmana Registered Member #3108 Joined: Thu Aug 12 2010, 05:37PM
I read the whole thing, and I have to say that is very impressive! It shows that HV is not just for fun, it has some potential uses too!
Just wondering, what is that yellow mineral you disaggregated from a rock sample?
Oneironaut
Fri Jan 14 2011, 11:30PM
Thanks for the comments!
The yellow gem was Sapphire if I remember correctly. I broke up everything from gold to diamond samples in that beast.
Brad
Xray
Sat Jan 15 2011, 12:30AM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
Excellent project and very cool website! smile
I constructed a hv pulse generator a few years ago, but it's only rated at 4KV with a 100uF pulse capacitor. I've used it to deform aluminum tubes and to shoot aluminum discs into the air, but other than "playing" with it, I found no serious use for it. As time permits, I'm going to construct a water-arc cannon and see how far I can launch a small projectile. FUN STUFF!
HIGH VOLTAGE ROCKS! (no pun intended!! LOL)
vircator
Sat Jan 15 2011, 12:13PM
vircator Registered Member #3217 Joined: Mon Sept 20 2010, 06:14AM
Hm, you are sure you have 10ns pulses? That would be an awful good timing... I am building a Marx which is contained in a metallic tube under pressure (to adjust the firing voltage and help to trigger the other gaps via electric field in the tube), but I have a hard time to get such fast discharge times.
Anyway, you did a great job! My brother-in-law works for a company doing the same to separate rocks.
Marcus Quintilian
Tue Mar 15 2011, 02:57AM
Marcus Quintilian Registered Member #3761 Joined: Tue Mar 15 2011, 12:29AM
I think i saw you on daily planet. as I rember you had to dissasemble it
