  • Guests: 55
SSTC sch help~~~
steven968
Thu Jan 13 2011, 12:39AM Print
steven968 Registered Member #3516 Joined: Wed Dec 15 2010, 10:40AM
Hi,
Here is a half bridge sch of Steve's SSTC, I was wondering if it works under DC or AC? Does it need a rectifier? or just use AC current.
thanks.
1294879192 3516 FT0 Fbsstcsch3
Gregory
Thu Jan 13 2011, 01:17AM
put AC current at "HOT", that diode is the half-rectifier, you don't need the smooth start circuit if you will use a variac
Dr. ISOTOP
Thu Jan 13 2011, 01:47AM
The half-bridge is driven by the driver circuitry, which is also on Steve's page.
The driver produces DC.
Thu Jan 13 2011, 09:29AM
bwang wrote ...
As Gregory says, this circuit runs on AC and D8 half wave rectifies the input, there is no large DC smoothing cap, only the voltage splitting capacitors for the half bridge.
The driver ONLY provides gate drive for the two MOSFETs.
