  • Guests: 58
Turnoff Voltage Spikes from Microwave Oven Transformers
Mon Jan 10 2011, 06:17AM Print
Today I was viewing the waveform of the output of a MOT on my oscilloscope to see how the saturation of the core changes the waveform and I discovered that the when turned off, the MOT generates quite a large voltage spike. From the two MOT's I tested it its on the order of 8 Kv. I believe that under loading, this spike would mostly disappear. However, those who do not already know of the large spike should take it into account if they use a MOT to power high impedance loads that are sensitive to over voltage.
From these spikes, one of two things can be determined. One is that microwave transformers are designed with a 8kv core to winding insulation to withstand these spikes, and are actually rated to reliably withstand the high voltages associated with resonant operation. The other possibility is that microwave transformers are only designed to be operated with a load, and should never be turned off at a full primary voltage without a load to prevent a potentially damaging voltage spike.
Here are two pictures from my DSO showing the normal waveform of a MOT under saturation and the turn off spike.
Looks like the forum doesn't let me upload .bmp images angry . I will try to covert them and post the pictures tomorrow.
Mon Jan 10 2011, 12:21PM
Well, the 4hv thing to do would be hook up a MOT to an ignition coil driver circuit to explore the turnoff spikes in more detail. smile
Antonio
Mon Jan 10 2011, 01:23PM
All transformers show this behavior. When you interrupt the primary current the energy stored in the primary inductance must go somewhere, and a pulse is generated. A suitable capacitor or a surge supressor in parallel with the primary winding will reduce the spike.
Tue Jan 11 2011, 12:09AM
Antonio, I understand that all transformers display this voltage spike. However, I was astonished by the magnitude of the spike, which I believe is made worse due to the extra leakage inductance of the shunts in a MOT compared to a standard transformer. And like I said, the large magnitude of the spike can tell us that we must never turn off a MOT while it is unloaded, such as when drawing arcs, or that a MOT is built with extra insulation and is a bit better made then what most people complain.
As promised here are the scope waveforms of the spikes, and the icky output waveform caused by saturation of the core.
1294704541 1316 FT105782 Newfile2
1294704541 1316 FT105782 Newfile3
Tue Jan 11 2011, 09:51AM
Here is an MOT circuit showing the use of a bi-directional protective diode transient peak clipper, apparently using two discrete diodes.
1294738982 543 FT0 Mot Circuit
Much more commonly, the bi-directional transient clipper or 'safety diode' is fabricated as a single device.
Its purpose it to protect both the capacitor and the transformer from the destructive transients you have observed.
Frosty90
Wed Jan 12 2011, 12:00PM
Frosty90 Registered Member #1617 Joined: Fri Aug 01 2008, 07:31AM
That seems most likely!
I once decided to push my luck and hook 3 mots in series in open air, with all the cores floating. When the secondaries were open circuit the thing hissed and crackled with corona very loudly! I stopped then, but I reckon theyd quickly die like this.
