  • Guests: 51
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
I need help I want to make a TC.
LIGHT
Mon Jan 10 2011, 03:56AM Print
LIGHT Banned on 4/6/2011 for unsafe, irresponsible behavior.
Registered Member #3442 Joined: Fri Nov 26 2010, 04:09AM
Hey guys, I wanbt to make a small tesla coil using a flyback as the powersupply, I need help, and maybe a simple schematic.
Thanks!
steven968
Mon Jan 10 2011, 05:17AM
steven968 Registered Member #3516 Joined: Wed Dec 15 2010, 10:40AM
you want the sch for flyback driver or SGTC?
just google "SGTC" or "zvs" you'll get some result.
Dr. ISOTOP
Mon Jan 10 2011, 06:46AM
You'll need to use a fairly high-powered flyback driver to get good results.
Also, it is against forum rules to ask for complete schematics.
LIGHT
Mon Jan 10 2011, 07:36AM
I want to make a small SGTC from a flyback , and the flyback will be powered using a 60watt SMPS.
As I cant make any other drivers at the moment.
Ruben
Mon Jan 10 2011, 10:16AM
Ruben Registered Member #3263 Joined: Sat Oct 02 2010, 04:43AM
I highly recommend 'deep fried neon', as well as a google search on tesla coil design to get you started with basic theory and design.
To get the most out of the forum (IMHO) you need to ask more specific questions. It's certainly doable, but 60 W may be pushing things a little low:
LIGHT
Mon Jan 10 2011, 11:26AM
Do you know where I can 'harvest' wire for the secondary?
LIGHT
Mon Jan 10 2011, 01:18PM
I'm very happy right now as I have just constructed a very small VERY! low power SGTC.
Although it works, it is HIGHLY inefficient.
To power it I used a 11watt tesco CFL ballast, the ca used was a 1kv rated cap, the spark gap was consisted of two multimeter probes tuned for the best sparks, and the secondary was wound by me, and I mean it's SHIT, so shit that there were heaps of wire in oarts of the coil, and there was corana forming around the secondary, I dont knwo how many turns, over 300 though and the primary coil was 3 turns of live mains wire, just live not ground neatural and live together.
I still have loads of wire left over from where I got the secondary wire (electron gun focusing coil) I'm going to make a much more efficient one, I will take my time winding the secondary coil and will up the 11 watt power source to 105watt.
Gunboat
Mon Jan 10 2011, 06:44PM
Gunboat Registered Member #338 Joined: Thu Mar 23 2006, 12:28PM
You can check out this site..might help you out with a few things.
or this one has all kinds of links.
LIGHT
Mon Jan 10 2011, 09:31PM
Thanks alot, mate!
Gunboat
Tue Jan 11 2011, 10:44AM
You are more than welcome,need anything else,ask,and I will see what I can do for you.
cheesey
