  • Guests: 44
GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
01/25 Our Finest Hour (64)
Looking for LOTS of sodium
ubuntupokemoninc
Sun Jan 09 2011, 05:06AM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
All i can find are pebble sized pellets, and i want a big brick, any one making or selling it confused
Lol I want to flush some sodium down an old toilet cheesey
william L
Sun Jan 09 2011, 05:46AM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
Don't burn your hands off. But, i suppose you could electrolyze salt water, but DO IT OUTSIDE! chlorine gas isn't always friendly.
Dr. ISOTOP
Sun Jan 09 2011, 06:12AM
Electrolyzing salt water produces NaOH, not Na.
You need to electrolyze molten salt.
Bjørn
Sun Jan 09 2011, 06:45AM
There is a reason that you have trouble finding your brick. It is a dangerous substance that is very expensive to transport. This sort of thing does not scale well and there is a possibility of you blowing your head off.
If you want to do stupid things like this we don't really want to know about it.
Adam Munich
Sun Jan 09 2011, 03:07PM
If you want to just make some booms, perchlorate flash powder is both cheaper and safer than sodium.
william L
Sun Jan 09 2011, 08:29PM
bwang wrote ...
No, when you electrolyze salt water, you get hydrogen, oxygen, and chlorine gas., effectively separating the sodium. not sure how you would keep it stable.
Kilham
Sun Jan 09 2011, 08:56PM
Kilham Registered Member #2814 Joined: Wed Apr 21 2010, 12:28PM
william L wrote ...
bwang wrote ...
You can't.
Sun Jan 09 2011, 09:26PM
The by-products of saline electrolysis depend on the electrode potential of the elements used for anode and cathode.
Where mercury is used as the cathode, the sodium liberated dissolves in the mercury to form an amalgam.
When this amalgam is placed in water, the sodium reacts to form a hydroxide solution, and the mercury is free to be used again.
On an automated, industrial scale, this technique is known as the Castner-Kellner Process.
Kilham
Sun Jan 09 2011, 09:46PM
Arg - forgot about that, I was too fixated on the use of fused NaOH (Castner process) and production of metallic Sodium.
Why is it that at the age of 13 when I made my own metal that it never crossed my mind to flush a load of it down the toilet?. I must have been very boring.
Mon Jan 10 2011, 02:44AM
I believe from my conversations with one of the companies that make solid Na and K, the salt is heated until it is molten. Then, a large current is used to start the electrolysis, yielding Na and Cl2. The heat from the conducted current keeps the bath molten. Of course, one has the issues of containment.
