  • Guests: 59
Bauerb2 (36)
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
Some problem with my first SGTC
hsieh
Sun Jan 09 2011, 02:16AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I build this SGTC according to the schematic found here Link2
But I only can get 1~2mm sparks.Why?
I tried to add or remove some primary turns.But this is even worsen.And primary capacitor (I use 10kv 500pF)get's hot.Why?
How can I fix it?
Thanks
hsieh
Sun Jan 09 2011, 02:18AM
I forgot to post my photo.
the spark is hard to photograph.
1294539536 1412 FT105642 Dscn7959
ubuntupokemoninc
Sun Jan 09 2011, 03:28AM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
well how much wattage are you putting in? people with the huge arcs put LOTS of power in!
Dr. ISOTOP
Sun Jan 09 2011, 04:04AM
What sort of capacitor are you using?
hsieh
Sun Jan 09 2011, 05:08AM
bwang wrote ...
I'm not sure what kind of capacitor it is but it can be seen in my photo.
ubuntupokemoninc
Sun Jan 09 2011, 05:29AM
well tell me how much power your putting in? because that small cap has to be limiting quite abit of power you need caps like this Link2,r:14,s:30&tx=109&ty=81&biw=1152&bih=641
or this Link2
and ct92404 (a user on youtube with tesla tutorials) said "not to use pointed screws for the spark gap because it will fire prematurely"
hsieh
Sun Jan 09 2011, 07:45AM
ubuntupokemoninc wrote ...
or this Link2
Is less than 10W.
So which is better?a single high voltage cap or MMC?
what is ideal for a spark gap?Can I use something round or cylindrical?
ubuntupokemoninc
Sun Jan 09 2011, 03:39PM
10 watts is your problem if you don't put much power in you can't get very impressive sparks! put more power in, if you want a nice tesla coil, get your self some neon sign transformers, or put a mot with a voltage quadrupler on it. but then you will need a mmc cap. witch are like $20 for a 15kv .02 uf witch should do the trick.
your very lucky you even get break out at all, my first tesla coil didn't even get break out on its own, put i could start an arc off of it from 15cm away!
this was my first tc, video taken witch a cell phone witch sucks!
I like my multi color secondary cheesey
hsieh
Sun Jan 09 2011, 04:03PM
So,even if a 10Watt SGTC is optimized, it can only produce 1mm spark?
or if I can optimize it I can get a spark longer than 1~2mm?
If I can find caps with very high voltage rating(55kv),is MMC still better?
I can't afford a NST and can't find MOTs.
ubuntupokemoninc
Sun Jan 09 2011, 04:13PM
what is the line frequency in your country, i can't afford an nst either mad but i have to oil buring ignition coils i'll sell you for $50
that will equal 440watts and you will get a nice output with that!
