  • Guests: 46
Wattage Ratings for sync spark gap tesla coils
Nah
Fri Jan 07 2011, 11:08PM Print
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
Hello,
What kind of ratings do you use? I see an ebay for a 28 watt moter, do you belive this will be enough? This will be a propeller design.
Thanks you!
Paul
Sat Jan 08 2011, 12:12AM
28 watts should be plenty if you make a very small rotor that is somewhat aerodynamic. My most successful srsg was with a microwave fan motor, and it stays sync. It could handle a single NST, or a pole pig if i wanted. It's all about the surface area and heat dissipating capabilities of the electrodes to aerodynamic ratio. Tested on NST, but a pole pig might be a little much, maybe a MOT.
Kolas
Sat Jan 08 2011, 03:31AM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
there is more to it then that. the distance of the electrodes from one another on the propeller matters too.
if you are dealing with a very high current source it is likely that a small distance will not provide enough down time for the arc to quench. thus you be left with a power arc in place of a spark gap.
