  • Guests: 42
whitch type of TC suits freshman?
steven968
Fri Jan 07 2011, 11:37AM Print
steven968 Registered Member #3516 Joined: Wed Dec 15 2010, 10:40AM
Hi all
I'd like to know which type of TC is the best for a freshman(the first TC), SGTC powered by a flyback?
thanks.
Fri Jan 07 2011, 01:21PM
If you can get a Neon Sign Transformer (NST) or Oil Burner Ignition Transformer (OBIT)
of the old type, heavy transformer, NOT electronic, then without doubt the easiest start is a SGTC.
Fri Jan 07 2011, 06:52PM
The easiest would be to build a small solid state Tesla coil such as a single-transistor based SSTC. This way you get some exposure with electronics, and don't need to worry about a high voltage transformer, a spark gap, etc...
Plus, it will serve as a good starting point as you work your way up to disruptive type solid state Tesla coils such as DRSSTCs.
Crunchy Frog
Mon Jan 10 2011, 10:20PM
Crunchy Frog Registered Member #2422 Joined: Tue Oct 06 2009, 02:41AM
The easiest way is to get an Eastern Voltage Research kit, but I suppose he's too modest to say that...
