  • Guests: 42
Help for my SSTC
Thu Jan 06 2011, 08:05PM Print
Registered Member #3581 Joined:
Hi! I'm a guy from Spain, and I need your help.
I want to build a solid state tesla coil, but I don't know how.
I tried some circuits and schematics, but they didn't work.
I have an oscillator circuit with 4046, but I don't know how connect the output on a mosfet driver (I have the IR2112). I would like that the driver don't have GDT. I need help, please.
Thu Jan 06 2011, 08:13PM
1294344833 3581 FT105456 Oscillator Cd4046
ubuntupokemoninc
Thu Jan 06 2011, 11:36PM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
this video completely explains how to wire mosfets and igbts Link2
Sat Jan 08 2011, 04:58PM
Hello again!
At the end I got a new schematic for the sstc with the cd4046 and ir2112. In the simulation, the circuit works very good, but I build it and didn't work. One of the capacitor of the power supply was burned. I doesn't know what I'm doing wrong.
In the oscilloscope of the simulation, the Channel A is the output of the cd4046; the Channel B is the high side of the ir2112; and the Channel C is the Drain for the mosfet IRFP250.
Thank you.
1294505925 3581 FT105456 Oscilloscope
1294505925 3581 FT105456 Schematic
ubuntupokemoninc
Sat Jan 08 2011, 06:11PM
how big is your cap? does it look like this Link2,r:3,s:0
Sat Jan 08 2011, 08:34PM
No, my cap is more big, is a cap of 2200uF to 35V
ubuntupokemoninc
Sat Jan 08 2011, 11:07PM
What I meant is it polorized like in the picture (like a barrel shape) thats what the schematic calls for, and all the filter circuits i've made i use polarized caps, and if they are polarized make sure they are going the right direction, that could be the root of your problem!
Sun Jan 09 2011, 09:43AM
You are right, I use two polarized caps, but they are in the right direction... but my problem doesn't it the cap, I'm here because my solid state tesla coil doens't work. I think that the mosfet gate is open, don't have any resistor, so open the gate produce an shortcircuit in the mosfet, and burn the power supply.
