  • Guests: 46
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Looking for a potential transformer
ubuntupokemoninc
Wed Jan 05 2011, 09:56PM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
I'm sick of the low voltage from mots,
will i be able to get a pt for $100?
Thu Jan 06 2011, 07:52PM
Probably not for $100.00, unless you get one from a salvage yard. The common 14.4kV:120V, 1.5kVA potential transformers which most people use typically go for about $300-400. You're best bet would probably get a small pole transformer. They have mini 3kVA units, or standard 5kVA and 10kVA units as well. Ebay sometimes have these around the $200-300 range, not including delivery.
But to answer your question, no, you probalby won't be able to get one for $100 unless you got one outside of the Tesla community, such as a salvage yard.
They are getting rare these days, so you will pay a premium.
ubuntupokemoninc
Thu Jan 06 2011, 11:15PM
yeah i'm building a pig, but i have yet to do the winding i'm weighting tell it warms up,
I want voltage, how much could i get an 80kv x-ray transformer for?
and my salvage yard won't sell me a pt as of liability reasons cry
Fri Jan 07 2011, 06:57PM
You don't want high voltage for a Tesla coil if thats your intended use. 14.4kV is a very good voltage. Above, that such as 28.8kV potential transformers which are fairly common as well introduce an entire new set of challenges when building a tesla coil such as high voltage stand-off, corona suppression, etc...
So if you're looking to use this for Tesla coil use, try to stay around 14.4kV-15kV.
Wolfram
Fri Jan 07 2011, 07:06PM
ubuntupokemoninc wrote ...
They tend to go for around 150 dollars, sometimes even more. Complete x-ray heads with the same transformers inside are often cheaper though.
