  • Guests: 38
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
High Current PSU
Thu Jan 06 2011, 09:53AM
Yes, but the intent of this thread seems more like, "I have these parts and would like to make arcs and burn stuff up with them!"
Seems kind of obvious to me what to do. Find the biggest, heaviest winding on the transformer, connect it to the carbon electrodes with some thick wires, start arcing and burning stuff. If the transformer starts to smell or smoke, quit and let it cool down. Repeat until you get bored or the transformer is destroyed.
The only thing is that smoothing capacitors might make the arc unstable. I would leave them out.
Also, that's not an ordinary transformer, it's a constant voltage transformer. That may complicate things. The two orange wires that connect to the grey cap can are a high voltage resonant winding that you may be able to pull some fun arcs from. smile Just be careful not to shock yourself on it.
pauleddy
Thu Jan 06 2011, 11:19AM
pauleddy Registered Member #2909 Joined: Wed Jun 09 2010, 12:31AM
Thank you Steve, I was wondering about that little gray cap and it's what it is for. As for the project my intent is not really to draw arcs, I'm shooting for about 5v-10v and as many amps as I can pull I have huge diodes to rectify it if I choose for a later project, like electroplating or a real big zvs I have plug this spare transformer in and have gotten about 30v and 50v out which is too high for my plans, so I'm still debateing if I should rewind it like a lot of perple do to MOTs
Thu Jan 06 2011, 01:35PM
I was under the impression that some welding transformers run at around 25V, while others run at around 48V.(I think some run at around 80V as well)
Why not try the carbons on the 30V coil and see what happens?
You'll need a welding mask, though.
pauleddy
Fri Jan 07 2011, 03:34AM
I hmmm I thought it was lower then that I think i need to do more reshearch, but I put out this idea here first more if I should try rewinding it, I think I will try the 30v idea. And I have a mask that I made
pauleddy
Sun Aug 07 2011, 10:13PM
well i took it and rewinded it, 5 turns of two bundles of CAT 15 wire, i get about 5V, and a lot of current.
i just need to find a way to measure what the amperge is. I it ran though a small graphite bar and made a video of it.
any idea how much current this is or know a way to calc it?
Mon Aug 08 2011, 12:26AM
pauleddy wrote ...
Looks like quite a bit. You should be able to get a rough idea by measuring input current and converting to watts (VI=W), if you have an AC ammeter.
pauleddy
Mon Aug 08 2011, 12:42AM
unfortnly i dont, but its less then 20A or the breaker would trip, which hasn't happen yet.
so lets say it was drawing 15A at 120V thats 1800W so at 5V that would be 350A, asumeming no losses and such... it seems to be pushing <100A now the next step is to find a way to rectify it, i do have a few diodes that are rated for 250A, at 1200V, that will bee a fun build.
Mon Aug 08 2011, 01:43AM
pauleddy wrote ...
. i do have a few diodes that are rated for 250A, at 1200V, that will bee a fun build.
I'm building a similar rectifier, using 300A, 1200V, TO-9 schottky stud diodes. I'll be posting about progress soon.
pauleddy
Mon Aug 08 2011, 02:53AM
well i have 2 ds250, and two simularly rated SCRs that i will try to make a full bridge rectifier, im currently debating weather or not to re wind the secondary to a higher votage, mabe 10v, so i have a theoritical max of 240A befor the breaker trips, if there's no loses
