  • Guests: 54
Cuter little flyback
Adam Munich
Wed Jan 05 2011, 12:10AM Print
I got another cute little FBT today, even smaller then the last. I don't think they make them (this style) any smaller.
Next to the cute one.
1294186188 2893 FT0 Dsc09230
Next to my biggest one.
1294186098 2893 FT0 Dsc09234
ZakWolf
Wed Jan 05 2011, 07:02AM
where do you find them so small ?
I cant make a vid right now i will work on it later. Its hard to capture how tiny it is and i dont have the best camera here it is :)
1294210893 3114 FT105309 Dsc00372
Adam Munich
Wed Jan 05 2011, 07:21AM
LittleVenture wrote ...
Old 5" TVs.
Wed Jan 05 2011, 07:56AM
I have/had some like this, they where in an air purifier. Ran with a KA555 driving an IRF740's gate. Not sure how i remember that so specifically 3-4 years later, especially since i did not even know what a datasheet was back then...
Dr. H.
Wed Jan 05 2011, 09:51AM
You can find really small flybacks in plasma globes and copy machines.
Cheers
Plasmana
Wed Jan 05 2011, 10:38AM
Plasmana Registered Member #3108 Joined: Thu Aug 12 2010, 05:37PM
They usually have encased cores to make then extreamly small, however I have seen in one plasma globe has an open core flyback, and it is about half the size what grenadier has.
I also have an old 5'' TV, I am just not too sure wether I should taking apart or keep it incase of emergency (as it is battery powered)
Adam Munich
Wed Jan 05 2011, 11:25AM
"and it is about half the size what grenadier has."
Do you remember what one?
:I also have an old 5'' TV, I am just not too sure wether I should taking apart or keep it incase of emergency (as it is battery powered)"
I wouldn't worry about that for two long, the uk is likely to drop analog tv soon.
Plasmana
Wed Jan 05 2011, 12:45PM
I was comparing the plasma globe flyback size to your smallest flyback that you found in your 5'' TV. Ill take a picture of it when I get back home (Im at college atm) in about 2 weeks.
Ash Small
Wed Jan 05 2011, 06:20PM
Grenadier wrote ...
All the digiboxes I have run off of a 12V adaptor. I don't see why they shouldn't run off of a battery.
Kolas
Wed Jan 05 2011, 07:46PM
Kolas Registered Member #102 Joined: Thu Feb 09 2006, 08:15PM
Here is the smallest flyback i've ever found.
It came from a plasma globe, and i suspect it outputs AC
1294256782 102 FT105309 Imag0053
