  • Guests: 34
scooter/motorcycle ignition coil drive frequency?
hsieh
Fri Dec 31 2010, 08:45AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I can't find car ignition coil(Modern car use a different ignition system?).But scooter or motorcycle ignition coils are easily available here in Taiwan(Taiwan has probably the highest scooter/motorcycle density in the world.Taiwan has 23million people and 10million scooter in a relatively small island)
Can I use car ignition coil driver circuit to drive scooter ignition coil?Is the frequency different?Which one is more powerful?Which circuit on the web is better?
thanks
Fri Dec 31 2010, 09:29AM
For your experiments, a motorcycle ignition coil will work just as well as a car ignition coil and will work almost exactly the same with all the drivers. As for the circuits to drive the ignition coil, I can only recommend that you try a few for yourself, few circuits are "better" then others.
