  • Guests: 38
ZVS Flyback Driver troubleshooting
Kiwihvguy
Tue Dec 28 2010, 12:15AM Print
Kiwihvguy Registered Member #3395 Joined: Thu Nov 04 2010, 08:42AM
Hi there guys!
I tested my ZVS driver today and there was no output whatsoever. I checked the primary windings to see it the turns were going in the same direction, and the inductor and MOSFETs got warm, but still no output. I know there's something wrong, but can someone please help? I would love to get some advice and help from experienced people.
Thanks,
Jozef
Adam Munich
Tue Dec 28 2010, 02:25AM
Can we see a couple pictures of your circuit?
Kiwihvguy
Tue Dec 28 2010, 02:50AM
Here you go:
1293504646 3395 FT104595 Dscf1551
Kiwihvguy
Tue Dec 28 2010, 02:54AM
Another one: (btw my camera makes the image size massive, so unfortunately I have to upload them one at a time.) sorry!
1293504865 3395 FT104595 Dscf1552
Tue Dec 28 2010, 03:02AM
Use 'Paint' to reduce the size before you upload them.
'Image'....'Re-size'...(assuming you're using microsoft windows.)
Adam Munich
Tue Dec 28 2010, 03:03AM
It looks like your ultrafast diodes aren't where they should be. They should be "crossing to the other side" but they don't seem to be.
See here: Link2
ubuntupokemoninc
Tue Dec 28 2010, 03:56AM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
maybe the fbt is bad, If the curcuit is oscilating it will interfear with an AM radio.
Adam Munich
Tue Dec 28 2010, 04:00AM
No it won't, unless you hold the radio 4 inches away from it.
Matt Edwards
Tue Dec 28 2010, 04:01AM
I agree, the flyback could be bad. Has happened to me a handful of times. Also, simple mistakes always seem to be the ones overlooked the most often. Double check the direction of your diodes :)
Kiwihvguy
Tue Dec 28 2010, 05:14AM
Thanks for the help. I think the flyback is fine and I will check the ultrafast diodes for any errors... Yeah, i noticed that the diodes go to a specific coil side so I'll try that. I hope that the MOSFET's didn't end being blown because they warm themselves and the heat sink up in seconds. Hopefully, when I fix this, because I will, I will be proud. Once I get it working, I'll upgrade to a 36v PSU with the 3 extra windings with 100 ohm resistors. But for now, I need to fix it lol.
