  • Guests: 55
ZVS Video
Adam Munich
Sun Dec 26 2010, 07:44PM Print
Finally got around to making one. Link2
Myke
Sun Dec 26 2010, 09:16PM
You shouldn't even be holding the "ground" wire in the video... It may be sitting at a couple kV higher than the ZVS circuit due to leakage currents and such...
Always use a chicken stick neutral
Wyatt
Sun Dec 26 2010, 10:01PM
Wyatt Registered Member #3490 Joined: Wed Dec 08 2010, 11:55PM
Nice.Very nice.
quicksilver
Sun Dec 26 2010, 10:26PM
You know, I really like the way you display your schematics on your pages. It's clean, neat and useful for a discussion. I've said this before but I notice now that you have made that type of illustration a "style" in your site. Frankly I really like it.
Adam Munich
Sun Dec 26 2010, 11:44PM
I did it to help the n00bs. I think it's the most simple way to display things.
I'm also not holding the ground electrode, I'm holding the rubberized clip lead below it; my hand blocks the view.
Just noticed a lot of typos. Fix'd.
Ash Small
Mon Dec 27 2010, 01:16AM
A picture tells a thousand words. Impressive schematics, Grenadier.
One point, and I'm probably wrong here, but I've been reading a bit on zero current switching and zero voltage switching on other sites, and I'd got the impression that the 'zero switching' concerned the transformer rather than the transistor(s).
I was under the impression, specifically, that if the transformer was switched when the current was zero, there would be no field to collapse, therefore no (in theory) transient voltages or wasted energy.
I was also (and I may well be mistaken here) under the impression that the discussion between zero voltage switching and zero current switching was something to do with phase lags, etc.
Some of this was read in the context of using current transformers controlling phase locked loops to control transistors via feedback.
Coming back to my original point, I was under the impression that the trick in a zero voltage switching circuit was to switch the transistor at a point when the voltage in the transformer was zero. Am I getting confused with something else?
(If you don't ask, you don't learn.)
EDIT: I think, specifically, that if the voltage across the primary is zero, the current, lagging by 90 degrees, is at a maximun, and that if it is switched at that point, the maximum amount of energy is delivered to the secondary, thereby producing a very efficient transformer.
This is what I thought ZVS meant.
Adam Munich
Mon Dec 27 2010, 01:24AM
I'm not certain myself. Anyone want to clear this up?
Ash Small
Mon Dec 27 2010, 03:17AM
I found this:
Not read it all yet, but from what I've read so far, it appears we may both be correct.
EDIT: It seems to say you switch it when the voltage at the drain is zero. I think this means the voltage across the primary is also zero.
Maybe someone else can clarify things here?
EDIT: also found this, mostly about buck converters, but I think it suggests I'm wrong and Grenadier is correct.
and this, from wikipedia:
"Quasi-resonant zero-current/zero-voltage switch
Quasi-resonant switching switches when the voltage is at a minimum and a valley is detectedA quasi-resonant zero-current/zero-voltage switch (ZCS/ZVS) where "each switch cycle delivers a quantized 'packet' of energy to the converter output, and switch turn-on and turn-off occurs at zero current and voltage, resulting in an essentially lossless switch."[13] Quasi-resonant switching, also known as valley switching, reduces EMI in the power supply by two methods:
1.By switching the bipolar switch when the voltage is at a minimum (in the valley) to minimize the hard switching effect that causes EMI.
2.By switching when a valley is detected, rather than at a fixed frequency, introduces a natural frequency jitter that spreads the RF emissions spectrum and reduces overall EMI."
Mon Dec 27 2010, 02:00PM
ZVS means that the transistors switch after the voltage across them has been brought to zero by some other method. ZCS means likewise for current.
Either one reduces switching losses in the transistors quite a bit. I don't think it reduces losses in the magnetics. Although, in the Mazzilli circuit that you guys call "The ZVS", the tank capacitor recycles energy that would otherwise be lost through leakage inductance between the half primaries.
HVPaul
Mon Dec 27 2010, 10:04PM
HVPaul Registered Member #2321 Joined: Fri Aug 28 2009, 05:13PM
Is that point to point construction?
Would you kindly post the the reverse side of the board?
Thanks
Grenadier wrote ...
