  • Guests: 59
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
selling 4 7868 pentodes
ubuntupokemoninc
Sun Dec 26 2010, 03:00AM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
I pulled them out of a unknown tube chassis, they appear to work, 1 is brand new, 2 are in pretty good condition and the 4th tube... the plate is pretty mangled rolleyes
Sun Dec 26 2010, 05:13AM
What does "Appear to work" mean?
ubuntupokemoninc
Sun Dec 26 2010, 02:26PM
tested them with my multi meter and theres no shorts mistrust
Sun Dec 26 2010, 07:18PM
Well tubes rarely, if at all, have a short inside. That test doesn't help at all, unless used to check continuity on the filaments to ensure they are intact.
To test you would need to actually use the tube by checking plate current at different grid voltages. If one has a mangled plate, i wouldn't trust the other 3.
Sun Dec 26 2010, 08:17PM
Front
It certainly is a bit of a puzzle to explain how a thermionic valve tester should turn out to look like this, if no more than a heater continuity test and a check for shorts are all that's needed to tell the good from the bad. smile
As pious folk will know, this is the exact model of valve tester that will be operated by Jesus at the Last Judgement to decide which valves will be admitted to Thermionic Heaven, and which will be consigned to a toxic waste dump near an infants' school in Mexico.
Tue Dec 28 2010, 01:02AM
803 Registered Member #2807 Joined: Fri Apr 16 2010, 08:10PM
Hi,
So what model tester is that? It sure doesn't look like a hickok to me. Is it a dreaded audiofool tester? mistrust
Doesn't look old to me.
Tue Dec 28 2010, 09:17AM
803 wrote ...
Hi,
Not even Batman can save you now, Boy Wonder!
This AVO Valve Characteristic Meter Mk III was manufactured by AVO Ltd, London, in the early 1950s.
The style of case, knobs, and typography, together with the layout of the front panel are typical of British instrument making c. 1945 - 1955.
As for audiophools, I'd guess their knowledge of thermionic valve testers was similar to your own.
Mon Jan 03 2011, 10:28PM
I see that your VERY humble Mrs. Mary.
No wonder that not many new things are being created.
Bjørn
Tue Jan 04 2011, 01:27AM
Enough of this off topic banter.
There are four tubes of unknown health for sale. Without high quality pictures I guess the price anyone is willing to pay will be very low.
Posts after this will disappear without a trace if they are not directly related to the sale and trade of the tubes in question, off topic posting is only allowed on the general chatting forum.
