  • Guests: 93
Skywarrior (52)
Dark Horse (54)
LD LANGER (38)
12/19 kywalda (63)
12/20 plazmatron (48)
12/20 rm203tech (17)
Safe temperature?
Gregory
Thu Dec 23 2010, 10:41PM Print
What is a max safe or "normal" temperature of the heatsink? i'm afraid to run my coil more than 30 seconds... i'm using the igbts irg4pc50ud with 30v at the gates.
what is the maximum heatsink temperature in yours coils?
Wyatt
Thu Dec 23 2010, 10:59PM
Wyatt Registered Member #3490 Joined: Wed Dec 08 2010, 11:55PM
What is a max safe or "normal" temperature of the heatsink? Keep it under 660 degrees celsius and the heatsink will survive(cant say much for the IGBTs though).;-)
TheBoozer
Thu Dec 23 2010, 11:03PM
I follow a pattern I found in some commercial units. Fans turn on around 135°F and the bridge gets disabled at around 165°F...
Heatsink temperature right next to the IGBT module...
Rich
Gregory
Fri Dec 24 2010, 12:01AM
thanks TheBoozer, i was afraid with 86ºF hehehehe, but i'm using a TO-247AC package igbt that isn't good for keep cool.. but i am thinking that this can survive at 135F. My fans are ON all the time.
What igbt are you using?
ScotchTapeLord
Fri Dec 24 2010, 12:32AM
According to the datasheet for your IGBT, the maximum temperature is 150 degrees F, so 135 is cutting it dangerously close. Performance decreases as the temperature rises so it's best to keep it at a manageable temperature.
My personal rule of thumb is "if it's too hot to touch I need to fix something."
Goodchild
Fri Dec 24 2010, 02:46AM
ScotchTapeLord wrote ...
I generally agree with this as well, if your heat sink is to hot to touch then you need to fix something (probably bigger IGBTs tongue)
Gregory
Fri Dec 24 2010, 04:19AM
i'm afraid to run my drsstc for a long time.. i made tests and in 35 seconds my heatsink heated 4ºC.. but in other tunes points (deferents tap position) my heatsing heated more.. like 8ºC, i don't now if is normal..
Fri Dec 24 2010, 05:03PM
No, 150 degrees C which is about 280F.
ScotchTapeLord
Fri Dec 24 2010, 06:17PM
Oops, my bad! That's quite a difference.
In my experience, though, failure comes shortly after exceeding touchable temperatures...
Gregory
Fri Dec 24 2010, 11:11PM
I ran my coil about 2 minutes and the heatsink heated C, I think that if a run for more time don't have problem...
