  • Guests: 15
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
assembling circuit boards
william L
Thu Dec 23 2010, 12:48PM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
I have learned that the hard way by using sand paper to sand off the burnt-on plastic from my tip
Is there any good tips for cleaning off plastic from irons? At the moment i am using my x-acto blade to scrape off the plastic.
I just scrape it on a wet paper towel 'till I cant smell it anymore. (I need to get a fume extractor)
still, I wish i didn't have a charred dent in my laptop cord. cry
Thu Dec 23 2010, 01:09PM
I use this Link2 at work
for soldering iron and de-soldering iron tips .... worth it.
(Dip the hot tip in it for a plating of iron)
Bored Chemist
Thu Dec 23 2010, 02:15PM
I have't checked lately (i.e. since the lead-free stuff came in) but they used to make a solder called "savbit" which already had copper dissolved in it. It didn't chew up copper bits as fast as regular solder.
Shrad
Thu Dec 23 2010, 04:10PM
these are cheap and great
an iron lasts years and a tip lasts at least one or two years of abuse, as long as you use a wetted sponge to clean the tip
Nicko
Thu Dec 23 2010, 04:59PM
Plasmana wrote ...
Klugesmith wrote ...
To clean or modify such a tip using a file is asking for trouble.
I have learned that the hard way by using sand paper to sand off the burnt-on plastic from my tip angry
I have a small brass brush for cleaning caked-on crud from the Metcal bits I use. Only a couple of bucks and its softer than the bit, so doesn't damage it, but stiff enough to clean any crud.
Sulaiman wrote ...
Snap. I use this too after using the above brush - very effective.
cavemen
Thu Dec 23 2010, 07:22PM
cavemen Registered Member #2008 Joined: Tue Mar 03 2009, 05:11AM
Ok.
I use a temperature regulator of a halogen lamp for a very good temperature regulation of my soldering iron.
The mystery is that cheap Russian soldering irons I had in Russia had unplated (?) copper tips that never disentigrated under any abuse.
The oldschool ones that were inherited from the Soviet times. I also used lead and tin solder which seems to take less beat on the tip.
Sounds like a conspiracy by the capitalists. :)
I think i will just buy some round 3/4 copper stock and shove it into my iron and forge the end to make a tip every time. Or take a piece of 1/4" sock to the lathe and drill a hole through the center to insert a skinny copper wire that will be sacrafitial.
I will switch into SMD electronics soon and I will use an electric frying pan to do my soldering.
Where is that "save a tip" solder sold at? (I am in the USA.)
cavemen
Thu Dec 23 2010, 08:20PM
Ok.
