  • Guests: 45
Germanium
1 2 3 4
Adam Munich
Thu Dec 23 2010, 02:11AM Print
Anyone know where I can get some semiconductor grade germanium? I'd like to make a replica of the first transistor to compliment my homemade LED. Possibly even make a radio with it.
Ash Small
Thu Dec 23 2010, 02:25AM
I can't directly answer your question, but......research 'epitaxy'....it is 'second generation transistors'....I think first gen. was something like 'homeotaxy'....it involves getting some vacuum gear......(at least, I think it does.....I'm interested in this project).....Unless anyone else knows better.........
Adam Munich
Thu Dec 23 2010, 02:29AM
Vacuum gear? The first transistor was made with glue, plastic and foil. tongue
1sttransistor1
Ash Small
Thu Dec 23 2010, 02:34AM
And gold electrodes......If you want to lay alternate layers of silicon and germanium you should be reading up on epitaxy.....just my opinion....for what it's worth.....
Adam Munich
Thu Dec 23 2010, 02:38AM
Ahh, gold foil is cheap. I'm sue it could be pulled off using copper foil too. Besides, a point contact would look cooler.
Ash Small
Thu Dec 23 2010, 02:41AM
I'm interested in watching this thread.......Good luck....
Ash Small
Thu Dec 23 2010, 02:59AM
I've just read the thread on your home brew LED and I'm impressed......Needs tidying up though.......read up on epiyaxy......
Adam Munich
Thu Dec 23 2010, 03:47AM
I'll look into it. what needs tidying up on the led? It was mostly just luck because I imagine it'd be very hard to find another nicely glowing piece of SiC like that.
Ash Small
Thu Dec 23 2010, 01:07PM
Sorry, I thought you'd made it somehow, I really shouldn't post after I've been drinking.
Epitaxy is basically a form of Chemical Vapour Deposition that grows single crystals. I've some literature on this stuff somewhere as I was working in a place that produces commercial systems for this, espacially the new generation of High Brightness LED's used for backlit TV's, etc.
Off the top of my head, I think they are using Gallium Arsenide for these, but I'll have to check.
SiC is still used as a substrate for growing GaN crystals for LED's.
There are at least a couple of us on here planning to try vacuum deposition of various types, I think Intrawinding is planning something along these lines as well, but I assume he's planning to start with stuff like coating lenses with aluminium (that's how most people seem to start). I'm more interested in Plasma Enhanced Chemical Vapour Deposition myself.
I assume it may be possible to grow these crystals using 'wet chemistry' (electrolysis) but I've not found any direct references to this,
Thu Dec 23 2010, 01:23PM
I made a diode by melting a bit of Indium into Germanium over a (cooking) gas flame
(decades ago) and a transistor can be similarly made by doing both sides of a thin strip of germanium - just a matter of temperature/timing and materials.
