  • Guests: 66
topload on a 4 mhz coil
tritium
Tue Dec 21 2010, 04:03PM Print
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
Hello guy's,
is it a problem if i'm going to use a topload on my EVR 4mhz coil,
I wan't to use a topload (toroid) because it looks better, but before I retune my coil I ask it here,
maybe someone has try this before?
Tue Dec 21 2010, 06:33PM
tritium wrote ...
Hello guy's,
Great question. Yes, a topload can be used, but recognize because of the high frequency, even a small topload will greatly affect the resonant frequency.
In summary, you can use a topload, but will need to basically redesign the resonator configuration to resonate at 4MHz with the topload. Also, if the geometry is radically different than the reference configuration, the coupling could change which could mean the Class-E driver may begin operating outside of its normal envelope of operation.
