  • Guests: 50
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Good source of high voltage caps
ubuntupokemoninc
Tue Dec 21 2010, 02:42AM Print
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
Got a gu-5b shades and i'm gonna build a vttc, and i needs some good quality caps, I need a 1nf and a 1.5 nf (schematic calls for 20kv)
Adam Munich
Tue Dec 21 2010, 03:16AM
You could try making them...
Link2,_3.5_nF
Tue Dec 21 2010, 05:48AM
No offense, but if you have the knowledge to make a vttc, you should know how to look for caps.
If you where to use this to it's full potential, you would need caps capable of many RF amps, and that is going to cost much more than your tube. The grid leak cap does not need to be too high quality, it will see less than an amp.
What schematic are you speaking of? You can go with the typical Hartley oscillator, but the values will vary hugely. There is a good deal of calculating values like all Tesla coils except for sstc's.
ubuntupokemoninc
Tue Dec 21 2010, 01:51PM
OK let me rephrase that, i know were to get good capacitors, i want good CHEAP capacitors wink
but i found abunch on ebay... a lot of 32 4k .01uf... FOR $9 and there fairly big sized!
Matt Edwards
Wed Dec 29 2010, 02:22AM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Im not sure how everyone else feels about it but i used some caps similar to these for my VTTC and they seem to be holding up rather nicely. Link2
Wed Dec 29 2010, 02:34AM
Oidium45 wrote ...
That makes two of us!
I got 11" sparks with that one cap and the 811A. (don't mind the other, it was gridleak, could have just as easily been a 1kv ceramic disk cap) Didn't realize they where so cheap... All 8 of those might just be what you're looking for, i have used some for an 833C once.
