  • Guests: 48
Barry (71)
Snowcat (38)
wylie (44)
02/01 Barry (71)
02/01 Snowcat (38)
02/01 wylie (44)
Toroid rings for a small coil
Matt Edwards
Sun Dec 19 2010, 05:52PM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
I was thinking about trying a toroid similar to Finn's on the homepage. The difference is that it will be on a much smaller scale. I will be using it on a SSTC that will eventually become a DRSSTC. the secondary is approximately 4.5x12 with 10" or so of actual windings (1000-1100 turns).
Anyway, I was hoping that everyone could give me the good, the bad, and the ugly on why I should or should not give this a try???
Thanks in advance
Goodchild
Sun Dec 19 2010, 11:38PM
You know I bet it could be done, the tricky part would be finding a way to bend the small tube into nice rings. If you could do that the rest would be a cake walk.
Eric
Matt Edwards
Mon Dec 20 2010, 12:51AM
How did I know that you would be the one to comment? Bending the rings is the easy part. Welding the inside of the seam will be the tricky part!
Mon Dec 20 2010, 02:51AM
Oidium45 wrote ...
If it where steel or copper, simply soldering then blending with a dremel would be easy, and it would yield a nice smooth seamless edge.
Goodchild
Mon Dec 20 2010, 04:58AM
Oidium45 wrote ...
Yeah I know I couldn't resist cheesey
You know they don't technically have to be connected, it's good to have them connected but you really only need to get the ends very close.
Like Arcstarter said I bet the best (and easiest) way would be to make the rings out of copper and solder them up.
Wyatt
Mon Dec 20 2010, 09:35PM
Wyatt Registered Member #3490 Joined: Wed Dec 08 2010, 11:55PM
Arcstarter is right.Soldering the rings makes life pretty easy.I built mine in a sort of unconventional way using copper cut to length then formed around a piece of scrap pvc .The larger support rings were formed around a tire cheesey and the inner support for mounting the mess to the top of the coil was formed around a tire rim (sorry I dont have a picture of it finished but I think you get the point).Skinned it out with small chicken wire.Looks pretty cool but I'll be honest I have yet to try it out.Quick and easy and made from junk on hand.
2045
Matt Edwards
Tue Dec 21 2010, 01:15AM
I have access to a tig so welding aluminum won't be too dificult minus space issues with smaller rings. I am considering copper though because I was thinking that since I am going to use a ring setup it would be cool if I made it look old fashioned (early tesla era-ish). My biggest concern was will there be any negative effects from using the rings verses a traditional toroid???
Goodchild
Tue Dec 21 2010, 06:02AM
From my understanding it is very similar to a traditional toroid with slightly less capacitance. The capacitance is base almost completely on the surface area of the toroid.
Now the rings, if spaced correctly can store the charge regardless of the air space between them (with slightly reduced capacitance). The toroid acts as one of the plates in a capacitor the surrounding air is the dielectric and all other suffuses (floor, wall, ceiling) make up the other plate (connected to ground) this and the seriesed stray capacitance of the secondary make up the C in the secondary LC.
I only have a basic understanding in this so if I'm wrong or some one would like to elaborate please do.
If you feel up to some "light" reading before bead you may want to check this out: Link2
EDIT: added link and some other info
Matt Edwards
Tue Dec 21 2010, 05:02PM
Thanks Eric.Wyatt looks like alot of work!
