  • Guests: 50
Half wave doubler
Corey
Mon Dec 13 2010, 03:46AM Print
Corey Registered Member #1902 Joined: Fri Jan 02 2009, 07:59PM
Will an electrolytic cap be suitable for this circuit? Link2 Thanks!
-Corey
ScotchTapeLord
Mon Dec 13 2010, 05:10AM
The capacitor will see AC, and depending on the load, possibly up to full voltage reversal.
But if you added a reverse protection diode to bypass the negative voltage across the capacitor then you could use a polarized capacitor.
Corey
Mon Dec 13 2010, 05:59AM
Will a single diode in parallel with the cap work?
-Corey
Freitsu
Mon Dec 13 2010, 08:16AM
Freitsu Registered Member #3147 Joined: Sun Aug 29 2010, 10:53AM
Yes, it will
Mon Dec 13 2010, 09:51AM
The cap will not see AC as long as its reactance is << the load impedance.
ScotchTapeLord
Mon Dec 13 2010, 04:30PM
The capacitor also has a 50% chance of seeing negative on transformer's first cycle... :)
He didn't specify his application so I think it would be best to add the diode for protection...
Corey
Mon Dec 13 2010, 06:19PM
I wanted a "sputter" type class-e SSTC, in which the timer is set to start at 0V and turn off at peak pulse voltage. This effectively makes crude VTTC/QCW type sparks at the right freq ~350khz. Thanks for all the input!!
-Corey
