  • Guests: 79
Electronic gold mine flybacks
1 2 3 4
ZakWolf
Mon Dec 13 2010, 01:57AM Print
Has any one ever bought one of these, Link2 I was looking to buy a couple of these and power a Tesla coil with them.... Are they any good?
Thanks
ubuntupokemoninc
Mon Dec 13 2010, 02:29AM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
Hey if there all the same put like 10 in parallel and run it on a zvs driver, i'm modifying my zvs to run on rectified mains, you could do that here!
Adam Munich
Mon Dec 13 2010, 02:37AM
I hope you have some petty good MOSFETs / IGBTs ubuntupokemoninc....
@littleventu
If you're planning on spending all that money to buy those and build a driver, why not just by a NST?
ZakWolf
Mon Dec 13 2010, 04:05AM
I already have made a tesla coil with only one flyback and got 4 inch streamers and about 5 inch arcs. I wanted to increase my wattage, so i was going to add more :)
I was thinking 2 or 3.... what would be better series or parallel ?
Adam Munich
Mon Dec 13 2010, 04:10AM
Certainly //. Series would undoubtedly kill them.
Make sure they all put out the same voltage though. Don't put a 5kV FBT in // with a 10kV one!
Mon Dec 13 2010, 09:49AM
You can put in parallel rectified transformers of different voltages but with small loading only the highest voltage one will output current.
quicksilver
Mon Dec 13 2010, 03:33PM
LittleVenture wrote ...
In all sincerity, these are a much better deal.
they will give you a decent arc; they need no driver and they are more robust. I compared them side by side. Buy one of each and test what you' get. remembering that one requires not only a driver config but supporting input, while the other needs only the simplest of set-ups. I put 25v / 5a in the "standard HV x-former and got a very fine quality 3cm arc.
Killa-X
Mon Dec 13 2010, 04:18PM
Can try one. The most I put in parallel of eBay flybacks was 5 :)
ZakWolf
Mon Dec 13 2010, 11:18PM
quicksilver wrote ...
That little transformer is better than a flyback? it looks very small, and only a 3cm arc. What is the output?
Tue Dec 14 2010, 03:42AM
I just purchased two of these transformers smile. If the voltage is high enough, sure it could drive a decent Tesla coil. A voltage as low as 2kv is high enough, you could multiply the voltage if needed.
