  • Guests: 37
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
555 counter curcuit
Fri Dec 17 2010, 11:48PM
Sulaiman wrote ...
- counting wheel rotations is fairly obvious
- if the rules allow it, ...
a piece of string/cotton of the target length attached to the start line could be used to stop the vehicle.
This is a better engineering approach
(guaranteed result, cheap, simple, reliable)
I agree with that philosophy: think outside the box; avoid unnecessary sophistication.
If the fixed string is not allowed,
wheel rotations could be counted mechanically by reduction gears or tape winding.
1292629094 2099 FT103136 K Timer
example: when told that the target distance is 41 feet, you calculate that that is 75 wheel rotations.
Instead of setting 75 on some electronic contraption connected to a wheel sensor,
turn the wheel backward 75 times while it's connected to appropriate gear in the clockwork timer.
Or during the run, have non-sticky tape wind from a cassette spool onto the axle. If the tail end of tape
is secured to the cassette hub, the axle will stall when there is no more tape available.
Ruben
Fri Dec 17 2010, 11:49PM
Ruben Registered Member #3263 Joined: Sat Oct 02 2010, 04:43AM
Lucky you! Just remember to do so religiously, especially if your buggy in any way taxes the batteries.
I've been in a similar sort of design/build competition, and found that it's much harder than it looks to build a vehicle which will actually drive straight by itself ( we had to go about 4 m). Keep anything related to the drive train very tight, accurate, and well made. Use pre-built units/parts if the rules and or your design allow it.
Another idea you could consider:
Make one axle out of threaded rod, and attach a nut which is forced to traverse the rod as the axle rotates. When the nut reaches it's desired position ( set number of wheel rotations) it could trip a micro switch wired to stop the motor. Even better, hook the axle up to a supply rail, and have the nut touch a contact, no switch required.
