  • Guests: 70
Touch the QCW or VTTC sparks
Gregory
Sat Dec 11 2010, 07:43PM Print
Why I can touch the sparks of a QCW or a VTTC ?
Avalanche
Sat Dec 11 2010, 07:47PM
because you have hands wink tongue
Sat Dec 11 2010, 09:11PM
Avalanche wrote ...
Perfect!
Greg, look up skin effect.
Ken M.
Sat Dec 11 2010, 09:32PM
You could also look up the Melting point of NaCl and figure that a VTTC or QCWTC arc is that hot, plus it turns arcs pretty clors =O
Sun Dec 12 2010, 02:43PM
You can touch the output of any coil. Because of the CW character of the discharges you won't feel much. That's because the frequency is way outside of what your nerves can detect. However there is harm being doing. The skin effect will make sure your blood vessels and nerves conduct almost all of the current. This can cause nerve damage and clothed blood vessels. So please don't try it, it's just not safe.
Hei
Sun Dec 12 2010, 03:53PM
Hei Registered Member #2808 Joined: Sat Apr 17 2010, 03:25AM
When you touch an arc from a traditional DRSSTCs, it's hurt, but it's much less painful when touching a small VTTCs. Maybe it's some matter with BPS on on time?
Sun Dec 12 2010, 09:16PM
Arcstarter wrote ...
Avalanche wrote ...
Perfect!
Actually, the skin effect is merely a myth. Skin effect typically only applies to "very good" conductors, of which the human body is not. Bert Hickman of the TCML list did a very nice calculation which showed that the skin depth for a human body was about 2.3 meters.
Here is his post from the TCML.
Hi Terry and all,
Not a bad guess! Overall, humans have a bulk resistivity of about 400
ohm-cm, varying between about 150 ohm-cm for blood, 285 ohm-cm for parallel
muscle fiber, to 2500 ohm-cm for fat. So, using 400 ohm-cm, skin depth at
200 kHz would be about 89 inches or about 2.3 meters. Unless you're large
enough to merit your own zip code, skin effect is pretty much nonexistent
for people and Tesla Coils.
-- Bert --
But as someone already said and hit it on the nail, the reason it "feels safe" is simply because the nerves do not react to electrical current at that frequency.
Patric
Mon Dec 13 2010, 09:59AM
Patric Registered Member #2899 Joined: Wed Jun 02 2010, 06:31PM
With high-frequency, the electricity does not interact with the nervous system, and therefore can not be felled. You can only get burned. This effect is used in operation rooms, to cut the flesh from the patient and coagulate the vains, so there is little to no blood.
To minimize the effects of muscle and neural stimulation, electro surgical equipment typically operates in the radio frequency (RF) range of 100 kHz to 5 MHz. The tension ranges from 100 to 400 V.
(sorry for my English frown )
dex
Sun Jan 09 2011, 08:07PM
dex Registered Member #2566 Joined: Wed Dec 23 2009, 05:52PM
Okay,how to construct a table top SGTC which doesn't give streamer jolts ? Except reducing top load size to minimum I don't know of any guidelines.Can I hear any tips from experienced coilers?Some small SGTCs (streamer lenght 5"-10") do bite while others simply don't.
Mon Jan 10 2011, 01:30AM
dex wrote ...
Due to the disruptive nature of sgtc's, they will all bite you. Sure, some more than others.
