  • Guests: 53
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
1mHz DRSSTC ?
dingo27
Fri Dec 10 2010, 09:25PM Print
dingo27 Registered Member #890 Joined: Tue Jul 10 2007, 10:06PM
Has anyone tried building TC at such high resonant frequency?
For imagination -
Secondary> i use 1100 turns 0.2mm wire dia on 4cm pipe, length of winding is 22cm (well, number of turns can be 200 more or less)
Primary > V type, 8 turns of 6cm diameter down and 10.5cm upper diameter.
resonant capacitance - i tried 16.3nf, which i cant tell if its ok or not, i dont have scope, but i can be sure it worked in DR, as sparks were really louder and also a lot (twice) longer.
For fullbridge i used IRG4PC50W , which are "ultra warp" speed 600V 55A IGBTs packed in TO247 package.
from here http://www.youtube.com/watch?v=FlD5Y8xeIdo, it seems it is possible to get decent spark length
Should i try to continue with that or am i just fighting with wind mills? Those IGBTs are not cheap, and if they fail everytime, maybe its just a job for cheaper mosfets...
Behaviour of this coil is just strange - spark length is increasing, decreasing, something wrong is going on here, i never occured this type of fail. Capacitors seems fine because coil is getting mad even without it. Sometimes it is working fine, and then a big spark occurs and continues to run, or not, it depends... Coil lasted to run OK for about 5 minutes.
Robert2
Fri Dec 10 2010, 10:26PM
Robert2 Registered Member #1773 Joined: Tue Oct 21 2008, 06:56PM
Steve Ward construction smile
ScotchTapeLord
Fri Dec 10 2010, 11:00PM
Here's a good thread for HF DRSSTCs... Link2
