  • Guests: 47
This brain teaser has thus far defeated me!
Fri Dec 10 2010, 12:57AM Print
i was given this question in a math class as a brain teaser but i cant wrap my brain around it, if any one can help me please do so...
1/2 is 3/4 of 5/6 of the number X
read as : Half is three quarters of five sixths of the number X, so what the hell is X? mistrust
i presume the answer will be an exact fraction.
as near as i get is this-> X times (5/6) is Y ....... Y times (3/4) = (1/2) now my brain is stuck.
EDIT: maybe-> Y times (3/4) = (1/2) if Y is (2/3) i think this much works !? (2/3) times (3/4) = (1/2)
is X = four fifths ?
TY, Patrick
Mattski
Fri Dec 10 2010, 01:25AM
You're on the right track, or at least you're on the same track that I'm on. You just have to substitute your first equation x*5/6=y into your second equation 3/4*y=1/2 since your first equation gives you y=something and your 2nd equation has y in it.
Edit: I think your edit came in while I wrote that post, and x=4/5 is the same answer I got.
Ash Small
Fri Dec 10 2010, 01:48AM
I make it 4/5, or 0.8
Fri Dec 10 2010, 01:52AM
Ash Small wrote ...
well all three of us working independently cant be crazy.
Mattski wrote ...
ok you solved it as a point of intersection of two equations.
Fri Dec 10 2010, 10:29AM
to me means that 1/2 = 3/4 * 5/6 * x, which in turn means that x = 4/5.
Coronafix
Fri Dec 10 2010, 12:27PM
yep. I get 4/5 too.
Ash Small
Fri Dec 10 2010, 12:50PM
The simplest way to work it out is 1/2*4/3*6/5=4/5
