  • Guests: 56
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
WANTED: Isolation transformer 1:1 120v
Matt Edwards
Tue Dec 07 2010, 11:30PM Print
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Hello everyone,
I'm looking for a isolation transformer 1:1 120v-120v approximately 15-20A or better.
I was hoping someone had something used to sell or trade. Feel free so send me a private message.
ubuntupokemoninc
Wed Dec 15 2010, 02:15AM
ubuntupokemoninc Banned on 1/22/2011 for repeated rule violations after multiple warnings.
Registered Member #3299 Joined: Sat Oct 09 2010, 08:11PM
I got 1 that will do 25 amps, you can actually vary the voltage just abit with a dile, its for cahnging the input voltage but i cheat with it to get 140 volts out of it tongue
how much are you willing to spend?
what would you trade it for?
Adam Munich
Wed Dec 15 2010, 06:55AM
That sounds like a variac to me.
ubuntupokemoninc
Wed Dec 15 2010, 08:07PM
Its not a variac, its a isolation transformer, that you set the line voltage too, 105-to 125 volts av and every 5 volts in between that, all i use it for is to cheat the voltage to abuse all my electronics tongue
ubuntupokemoninc
Thu Dec 16 2010, 11:57PM
I saw your dual 811a tc on you tube, and thought mayby you'd trade that transformer for your 2 811a tube
Matt Edwards
Fri Dec 17 2010, 05:55AM
Ill consider it dude. They would be hard for me to replace. And I am having too much fun with them. I pulled them from a heath-kit kilowatt linear amplifier. 4 matched 811a's all near new.
Fri Dec 17 2010, 01:16PM
Grenadier wrote ...
A variac is not isolated.
ubuntupokemoninc
Fri Dec 17 2010, 09:35PM
ITS NOT A VARIAC, IT SAYS ON THE TOP IN WHITE LETTERS "ISOLATIONS TRANSFORMER"!
Sat Dec 18 2010, 09:48PM
ubuntupokemoninc wrote ...
Actually, YES it is. Its what is more commonly known as a "double wound" variable transformer, which yes, are "isolated" variacs.
I know i said variacs are not isolated (single or dual layer variacs), which in most cases (as much as the variacs people usually have or refer to), but this special class of variacs are isolated.
And that is what you have.
Of course, a picture is worth a thousand words, so if you can post a pic, it would be helpful to all!
