  • Guests: 22
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
3 (and 5) stage CW multiplier
Freitsu
Tue Dec 07 2010, 11:07AM Print
Freitsu Registered Member #3147 Joined: Sun Aug 29 2010, 10:53AM
This is my experiment on making a CW multiplier with ordinary components that I could get ahold of in this city. (cheaply!!)
The caps are made following the instructions found at this place: Link2
And the HV diode chains are made following these instructions: Link2,_30_A_peak
but I changed it to 30 diodes (only needed them to hold up to 30kV) and I didn't put oil in the PVC tubing.
Current limiting resistor is made out of 250 0,6W resistors making the total resistance to ~35kohm, I filled this PVC tube with sunflower oil.
The longest spark I have gotten with this is about 10cm (shown in pictures)
The purpose of this experiment was to test if a CW multiplier with this capacitance is enough to drive my coolidge x-ray tube (small dental tube) and I can say it was enough, update on that is coming in a new thread in the future.
Sidenote on x-ray testing: I'm getting some real HV caps and diodes from ebay so I can make the whole machine portable.
3-stage (555 driven): Link2
5-stage (ZVS driven): Link2
5-stage with slightly better PSU: Link2
And here's some pics for you all!
1291719759 3147 FT0 Pict0003 2
1291719759 3147 FT0 Pict0001
1291719759 3147 FT0 Pict0005 2
1291719759 3147 FT0 Pict0006 2
Edit: added short clip
Edit: added another clip
Edit: added yet another clip
Tue Dec 07 2010, 11:44AM
Golly what fun, Freitsu! smile
I especially like the very literal circuit diagram layout on the table. Does it make a good hiss?
My smallest tube - a Svetlana BS7 - starts talking to the outside world through a beryllium window at 4kV, and would run away and hide in the woods (of which you have a great many in Finland!) if anything like that giant spark came anywhere near it.
I look forward to hearing more of your adventures with nanometric waves.
Freitsu
Tue Dec 07 2010, 01:18PM
Proud Mary wrote ...
You bet! smile
Freitsu
Mon Dec 13 2010, 08:12AM
A quick update, a decided to upgrade it to a 5-stage for more voltage and add ZVS driver instead of 555 driver for more power. Look at the video in first post!
GluD
Mon Dec 13 2010, 04:30PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
How much capacitance are you using? Very nice cloud in the 555 video smile Im also building a CW.
radhoo
Mon Dec 13 2010, 04:40PM
ZVS is nice, since it gives you a lot more power / shorter charging times, but you might want to double check your voltage output and make sure it is optimum.
For me most ZVS drivers put out a relatively low voltage, compared with a PWM driver. Some flybacks however seem to do a better job than others.
Freitsu
Mon Dec 13 2010, 05:09PM
GluD wrote ...
It's actually more corona in the second video but it was somehow not the optimal filming contions when I shot it so it doesn't show well... smile
Capacitance is approx. 3nF for each cap.
radhoo wrote ...
The AC flyback is outputting quite high voltage with ZVS actually (est. 15-20kV at 200W power) but ofcourse PWM driver would output more voltage (maybe even 25-30kV at best)...
Mon Dec 13 2010, 10:35PM
Very nice smile. If i ever get some diodes, i think i may try to repeat your results! I would likely use polyethylene instead, even though the capacitance per given area would be lower, because i have a lot of it.
Good work!
Freitsu
Tue Dec 14 2010, 06:08AM
Thanks, Arcstarter! It was very satisfying (you know what I'm talkin' about! cheesey) to see those long sparks flying from something as simple as this! I must say though it was very tedious work soldering those diodes and resistors together but was well worth the effort.
Something that is really tempting me is to try and run it non currentlimited, I can only imagine how loud that spark would be, but the diodes would surely not survive that kind of abuse...
