  • Guests: 24
10/09 sbs_2010 (34)
10/09 SoundDoc (50)
10/10 Ryan Parle (44)
PIC18F2550-based, hyperfast, 200 nanosecond resolution Projectile Speed trap
TheMerovingian
Mon Dec 06 2010, 10:42PM Print
In order to build a speed trap with similar characteristics of the commercial ones with fast response, wide speed range i decided to design my custom project.
The sensor are photodiode based, with LM393 comparator, wired to have very fast response time and keep the error of maximum 1 LSB of the counts (200ns)
The counts are from 200ns to 3.35s (timeout). The sensors are 10cm spaced apart so, an hipothetical 1Km/s projectile would spend 100us +- 0.2 us time to travel it, giving a resolution of 0.2%
The timer uses hardware CCP1 and 2 modules (Capture/compare/PWM) so no software delays.
THe speedtrap works regardless of which is the first sensor crossed.
THe pic is programmed in picbasic pro and features, full floating point operations (sum,diff,multiplic,division,sqrt) (numbers with 32 bit mantissa and 8 bit exponent) with suffix notations , significant digits (automatic) management, automatic kinetic energy calculations . Shot statistics (avg, max, dev.st) with 4 memory slots, and single shot memory with 14 positions.
I tested my coilgun pistol with it obtaining:
Max:
Speed: 25.0 m/s
KEnergy : 1.47 J
Average:
Speed: 23.9 m/s
KEnergy : 1.34 J
Min:
Speed : 22.7 m/s
Kenergy: 1.22 J
St.dev:
Speed: 0.621 m/s
Kenergy: 68mJ
Now i need to build the case for the circuitry.
Some photos of the project:
1291675353 14 FT0 Cimg3396
1291675353 14 FT0 Cimg3397
1291675353 14 FT0 Cimg3398
1291675353 14 FT0 Cimg3399
1291675353 14 FT0 Cimg3400
1291675353 14 FT0 Cimg3401
1291675353 14 FT0 Cimg3402
1291675353 14 FT0 Cimg3403
1291675353 14 FT0 Cimg3406
Turkey9
Thu Dec 09 2010, 12:46AM
Nicely done! Could you give a schematic if you have one? I might try to do something similar with an older PIC.
TheMerovingian
Fri Dec 10 2010, 07:44PM
which type of pic do you want to use?
Turkey9
Sat Dec 11 2010, 08:50AM
I've got a bunch of 16f690's that I ordered thinking that the 18f series were all 16 bit. You're using a 20MHz clock, correct? If I remember right that gives an instruction cycle time of 200ns.
I know photo diodes are really fast, but aren't they really low level? Is that what the comparator circuit does? Trigger when there is a change in the diode output?
I've also never worked with LCDs. Are the pinouts pretty universal? I pulled a small LCD out of something commercial but it had a header on it that plugged into a main board, do you think I could drive this myself?
TheMerovingian
Sat Dec 11 2010, 01:06PM
Turkey9 wrote ...
Yes, 20MHz means 50 nanosecond cicle, since one istruction is 4 clock cicles, you get 200ns. For mobile point math you need 18 series Pics, but it isn't really necessary. you can use fixed point math,
Turkey9 wrote ...
THe photodiodes with the irradiation i use (100mA led driving) swing about 1V with 22Kohm load resistor, that's enough to trigger the comparator (with a bit histeresys), since is use 300mV threshold
Turkey9 wrote ...
The pinout is pretty much the same for alfanumeric LCDs based on HD44800 controller (almost all alphanum)
