  • Guests: 37
  • Most ever online: 441
Carl A. Willis (45)
10/03 TwirlyWhirly555 (33)
10/04 Michael W. (36)
10/05 GhostlyFigures (36)
This toaster isn't UL approved.
magnet18
Thu Jun 16 2011, 04:00AM
It took 7 months to plug it in?
Also, that scares me.
Did you eat the toast?
Bet you can have some fun measuring voltages at different points though :)
Adam Munich
Thu Jun 16 2011, 04:03AM
magnet18 wrote ...
It took 7 months to plug it in? -- It was a really long power cord.
Also, that scares me. -- Meh
Did you eat the toast? -- Of course
Bet you can have some fun measuring voltages at different points though :) -- Measuring current would be more exciting.
magnet18
Thu Jun 16 2011, 04:36AM
Nah, current is the same everywhere, pretty boring.
ConKbot of Doom
Thu Jun 16 2011, 11:30AM
time to make it UL ( and CE ) certified on the easy!
Nah
Fri Jun 17 2011, 05:55PM
The Bagel version
4 kilowatts
It has the side effect of warping the bagel and having to drill holes in it, but does it toat!
A final versin will be presented in a month
THE BATTEL OF THE 4HV TOASTERS!
Forty
Sun Jun 19 2011, 05:45PM
@grenadier
I think the wire has to be a lot closer to the toast
someone should make a toaster using a bunch of high temperature arcs from flybacks.
or a skillet that's heated by mosfets
Sun Jun 19 2011, 06:07PM
Forty wrote ...
You've got me thinking Jacob's ladders now, Forty
Nah
Mon Jun 20 2011, 12:11AM
Inserting metal object in toast and using a induction heater? Now, that would be toasty, even if there is a bit of molten metal in there. The spice of life!
Mon Jun 20 2011, 11:47AM
Nah wrote ...
A metal plate either side of the toast, and heated by induction, may be more practical.
Bored Chemist
Mon Jun 20 2011, 12:13PM
To paraphrase Crocodile Dundee, "That's not a toaster.".
When I was a kid we had a coal fired central heating system. It was rated for about 10KW thermal o/p if I remember rightly.
At the bottom was the ash can and there was a cover over it which restricted the air flow through the fire.
So, if you took that cover off you could "over run" this thing.
Specifically, you could get a very noticeable draught through it.
It's difficult to feel the breeze when it's less than about a metre a second so lets assume that's the velocity. The cover was about 40 cm by 10 cm. So the bulk flow of air must have been something like 0.04 cubic metres per second (or more). That's about 50g of air each second of which about 10g was oxygen which would react with about 4 grams of carbon per second. Carbon gives about 25 KJ/g when burned so that's roughly 100 KJ per second i.e about 100 KW.
So I was over running it roughly 10 to 1.
The other thing about this was that if you emptied the ash out of the ash pan, and put a piece of bread in there (on some nice clean foil) yo could make toast in about 3 seconds per side.
Let me know if anyone here makes a more preposterously over powered toaster.
