EVR 4Mhz coil - audio circuit
tritium
Sat Dec 04 2010, 01:18PM
Registered Member #2591
Hello guys,
I want more power so I am making a more powerfull class-e amp. and bigger coil, for the music input I wan't to use the schematic that EVR uses, does this circuit run also at 150 volts?
the transistors are 300 volt, so I think it works but i am not sure, maybe i need to change some resistor values...
any help would be great.
