  • Guests: 54
Mica Caps
Adam Munich
Fri Dec 03 2010, 04:25PM Print
Just curious, has anyone eve tied making capacitors out of sheet mica? It's available online cheaply and it has a very high dielectric strength of 3kv/mil fo the average stuff and sometimes even 9kv/mil fo the premium quality stuff.
It could make fo some really nice TC capacitors. with some AgNo3 you can make you own silver mica caps!
ScotchTapeLord
Sat Dec 04 2010, 01:14AM
Could you give a link to a place that sells it?
My guess is that you can't entirely be sure that it is flawless enough to use as a dielectric. Any irregularities in the surface would compromise its ability to stand off high voltages, especially at radio frequencies.
It's probably worth a try, though.
Adam Munich
Sat Dec 04 2010, 02:40AM
This looks petty flawless, Link2
This is much more flawed, but it may work ell too. Link2
Since mica has such a high dielectric constant, it can be very thin. Thin dielectric = High capacitance. If you silver plate it then you;
A) Are as close as you can get to the dielectric (high capacitance)
B) Have very high stability.
I don't think it would take much mica at all to make a 20kV 20nf cap bank.
Coronafix
Sat Dec 04 2010, 06:08AM
I've tried it with the stuff like in the second link.
Works fine for line frequency HV but arcs straight through at RF.
Adam Munich
Sat Dec 04 2010, 06:17AM
Hmm, so who's going to try the flawless stuff then?
Pinky's Brain
Sat Dec 04 2010, 12:57PM
At a couple of order magnitudes in price/m2 over mylar, and a couple orders more for BOPP packing foil ... would it really be worth it?
Adam Munich
Sat Dec 04 2010, 03:17PM
Probably not...
Has anyone tied silver plating in capacitors though?
radiotech
Thu Dec 09 2010, 12:50AM
Could you somehow coat the mika with silver
vapor, perhaps by using silver electrode in an
arc that happens in a vacuum furnace?
Adam Munich
Thu Dec 09 2010, 12:53AM
Use AgNO3. Link2
