  • Guests: 50
aonomus (38)
12/07 aonomus (38)
12/08 Wizzup (30)
12/09 Killa-X (34)
Temperature Coeffcient for a Resistor, 100ppm.....
Fri Dec 03 2010, 08:48AM Print
what does this mean, change of expansion (physical) or change or resistence (electrical) ?
i cant figure this out...@100ppm
Bored Chemist
Fri Dec 03 2010, 09:07AM
It means that the resistance will change by 100 parts per million for each degree C change in temperature.
Fri Dec 03 2010, 09:27AM
So, if at 23 C degrees, Ohms = 200M, and then 45 degree C rise above that....
(100/1,000,000) = 0.0001
0.0001 x 45 degree C rise = 0.0045
0.0045 + 1 = 1.0045
1.0045 x 200M = 200.9 MegaOhms
so i gain ~0.500% of 200M just from temp rise?
Sat Dec 04 2010, 09:41PM
Patrick wrote ...
So, if at 23 C degrees, Ohms = 200M, and then 45 degree C rise above that.... so i gain ~0.500% of 200M just from temp rise?
Yup.
On the datasheet, TCR means "Temperature Coefficient of Resistance" to distinguish it from, say temperature coefficient of mechanical expansion. A copper wire gains about that much resistance (0.4 %) for a 1 degree C rise. The ROX series includes R's with guaranteed TCR ratings of 200ppm, 100ppm, and 50 ppm; perhaps the latter are not much more expensive.
Also note that the datasheet gives a Voltage Coefficient of Resistance.
Looks like at 10 kV per resistor, its resistance would be down by at least 4%.
Remember, Ohm's "law" is a just a very good approximation for behavior of many real materials in a widely useful range of electric field strength and current density.
