  • Guests: 67
Primary woes
Adam Munich
Fri Dec 03 2010, 04:31PM
Heat dissipation depends on the power you put into the mosfet. Use ohm's la to figure it out.
I^2*Ohms = P
Assuming the maximum current of 33A;
(33^2) * .07 = 76.23
But a much better formula fo mosfets is
P = Id * Vds
Id = current @ the drain
Vds = voltage across D@S
Meatball
Mon Dec 06 2010, 04:46PM
Meatball Registered Member #2401 Joined: Mon Sept 28 2009, 04:25PM
Alrighty,
I got the circuit up and running this morning.
When I first fired it up, one of my ATXs decided not to work, so I test my inital run from 12V, not 25V.
It strikes an arc at 1cm, which can be drawn out to about 2 inches, which is way longer than I expected from 12V.
I'm going to find me a couple more ATXs.
By the way, the FET heatsinks only barely get warm after 5 min of arcing, but again that's only from 12V. At higher voltages, I expect a medium size fan will work just fine. Thank guys!
Matt Edwards
Mon Dec 06 2010, 05:17PM
That's great dude! Let's see some pics
Meatball
Wed Dec 08 2010, 05:31PM
How about a video?
Thanks all! I used no fan on this run since it was only 12v, and it was very cold in the garage from the start-up.
