  • Guests: 60
TESLA Question: What kind of coupling better
Joyeep
Wed Dec 01 2010, 01:42AM Print
Joyeep Registered Member #2632 Joined: Sun Jan 17 2010, 01:46AM
In the picture below, for DRSSTC concerned, which is better, A OR B?
1291167771 2632 FT0 Quest
Coronafix
Wed Dec 01 2010, 05:02AM
Start with A, then once all the tuning is done you can increase towards B to get btighter coupling.
Luca
Wed Dec 01 2010, 09:18AM
Luca Registered Member #2481 Joined: Mon Nov 23 2009, 03:07PM
As "rule of thumb" coupling factor (k) should be between 0.15 and 0.2
It is not easy to measure k, but with a program such JavaTC you can perform quite accurate simulations and then have a quite reliable estimation of the k factor of your coil.
Regards,
Luca
Wed Dec 01 2010, 11:19AM
B would be better if it didn't flash over and burn up the coils.
For small DRSSTCs, you want the tightest coupling possible before flashover.
For large ones, there are sweet spots of coupling, "notches" etc. the same as a SGTC has. Steve Ward is the expert on this, I only build small ones.
Gregory
Wed Dec 01 2010, 02:24PM
you need know that when two LC ressonants corcuits are magnetic coupleds the ressonant point down and create another point more high. this depend of the coupling, if you tune in A and after you put the coumplig to B, the tune will not be perfect
Joyeep
Thu Dec 02 2010, 02:06AM
Thank you, I used the B, to design a high degree of change is the best solution
