  • Guests: 19
Thomas (40)
VulcanBB18 (50)
07/20 rev (49)
07/20 Cheech707 (35)
07/20 M_Gargantua (35)
Scintillation Probe (Photomultiplier/NaI)
first  3 4 5 6
Thu Jun 09 2011, 05:07PM
Ash Small wrote ...
Proud Mary wrote ...
Nicko wrote ...
How did you end up with a bucket of goulash out in the wilds (of the South Downs?)
Goulash World's Miss Goulash Award for International Goulash Year, of course!
Did you really not know that I was Goulash Queen 2011, Nicko?
But it says here:
that the International Goulash Competition 2011 isn't until September....I'm confused now!
Impostors! Frauds! Mountebanks! How could anyone doubt that I was Miss Goulash 2011!
radhoo
Fri Jul 15 2011, 12:31PM
Here is the emission spectrum, computed using FFT on the sound card data . Software used PRA and INTUNE:
This can be used to identify the radioisotope emitting the particles detected by the probe like in the expensive dosimeters.
1310733064 1938 FT101817 1min Nothing 1min Cs137
Fft
The last graph is a energy/event frequency representation. There are two energy peaks. The isotope used was Cs137 (from an old spark gap tube).
Fri Jul 15 2011, 02:15PM
radhoo wrote ...
So are you saying that the big peak is the 137mBa 661.6 keV gamma line, Radu?
1310741165 543 FT0 137cs Decay
You need to get some additional calibration standards sorted out before your relationship to this world becomes completely arbitary - often one of the first signs of serious mental disorder in my experience! smile
If you put an Al filter in front of the 241Am pellet from a smoke detector to block the alphas, then the 59.5 keV γ peak will be so very much larger than the other feeble γ emissions (if you can detect them at all) that you can be certain of its identity. With the alphas filtered out, you can consider it as a monochromatic 59.5 keV γ source for
most ordinary non-critical applications.
Afterthought added later: The 59.5 keV emission is not exactly bursting with meaty goodness, and I've seen pocket GM detectors using ZP1313 and similar miniature dosimetry tubes that couldn't detect it all. Just so you know.... smile
radhoo
Sat Jul 16 2011, 01:26PM
I'm new to this field, and just joined a group where this kind of setups are somehow ordinary. Tens of different PMT tubes, scintillation crystals, all for one purpose and some impressive results.
So I'll do my homeworks quickly and hope to have a nice spectrometer soon.
It seems others managed to use a microcontroller for this purpose, something that didn't work for me, or at least not as expected. The key factor seems to be a module to "Sample and hold" the "over-discrete" (too short) scintillation events. Files attached. Not very complicated at all!
]gamma_grapher_v0_hand_drawings.pdf[/file]
]mca_rad_test.pdf[/file]
radhoo
Sat Jul 16 2011, 01:30PM
Some pictures for those too lazy to open the above PDF's:
1310822935 1938 FT101817 Schematics Sample And Hold 1310822935 1938 FT101817 Sche2
My scintillation probes are industrial and so they are the result of a professional design. I expect to get some excellent results once I manage to build a reliable counter, FFT processor and spectrum representation on LCD. For now they seem to respond well both to x-rays and Cs137 radiation (you can hear the clicks in the heatsets, when using an audio sound card). When using PRA and INTUNE I can do the graphs above. First is a signal representation, straight forward: without and then with a radiation source, the other is a FFT spectrum as computed by PRA based on the signal recorded. I don't know how to calibrate it yet.
Wed Jul 20 2011, 11:58AM
A promising start, Radu! smile
Did you know that a few of the common Russian GM tubes were designed so that they could also operate in proportional mode, like a tail on the low voltage end of the Geiger region?
I've forgotten which type numbers they are, but if you are interested in gamma proportional spectroscopy, I'll see if I can find them again.
I was very lucky to buy the complete range of Svetlana Be-window proportional tubes covering 1.5 - 40 keV from a Bulgarian dealer a few years ago, but I've never seen them for sale anywhere since then.
radhoo
Wed Mar 07 2012, 02:37PM
I am looking for a larg NaI or plastic BGO scintillation crystal for a 9cm diameter PMT tube, posted here: Link2 , the M12FS100 . Any ideas where to find some?
Wed Mar 07 2012, 07:36PM
I bought BGO from this ebay dealer in America Link2
a few years ago, and I see he still has some now.
You can always glue smaller pieces together with cyanoacrylate to make one larger sheet, with no loss that you will be able measure.
Take care if you buy NaI(Tl) scintillator second-hand, as it is hygroscopic, and old NaI(Tl) may disappoint.
Organic scintillators are often cheaper and easier to get - naphthalene (as used in moth balls) for example.
This ebay seller Link2
will cut anthracene-based plastic scintillator to size, for very much less than you would pay for BGO.
radhoo
Thu Mar 08 2012, 09:35AM
Thank you, with the last one, Geo, I managed to get in contact on a group dedicated to this topic where he is a mod.
How can you tell that is anthracene-based plastic ?
Thu Mar 08 2012, 10:26AM
radhoo wrote ...
Sorry, Radu, I didn't make myself clear: it is the organic scintillator dissolved in the plastic that is anthracene, not the plastic itself. How do I know? Because it says so in the datasheet to which the ebay seller kindly gives a link! smile
In any case, anthracene is one of the most common active ingredients used in plastic scintillators.
PS: Don't forget that the natural mineral fluorite (CaF2) is a very fast scintillator, with about half the brightness of NaI(Tl) and little of the cost if you buy it on ebay in the rocks/fossils/minerals section
first  3 4 5 6
