  • Guests: 33
Mycologist (34)
Some_Polak (31)
brandon3055 (31)
10/15 OiD (38)
10/15 jolty (50)
10/15 Baran (29)
Light goes pretty far
Adam Munich
Sun Nov 28 2010, 04:29AM Print
I was sitting out back and I notice faint shadows on my shed. I had no idea why they were there, so I walked in front of it and looked around. It turns out the light was a street light, a mile away on the other side of the woods. Pretty crazy that it made it all the way through those branches.
I then took a picture, it was blurry because autofocus doesn't work well at night, and it was noisy too. I wish I had a lens with a larger aperture, but those cost a crapload and a half. Nonetheless it was a picture, 20 second exposure. It was quite a bright pic, and I was thinking to myself that all that light is coming from streetlights and headlights for miles around. Pretty crazy.
1290918485 2893 FT0 Dsc08028
Sun Nov 28 2010, 02:16PM
heh.
could be that the branches are acting like a series of pinhole lenses.. interesting.
-A
Renesis
Mon Nov 29 2010, 03:17PM
Renesis Registered Member #2028 Joined: Mon Mar 16 2009, 08:13PM
wrote ...
Word. I've seen light from other galaxies and stuff tongue
Adam Munich
Wed Dec 01 2010, 04:33AM
Yeah. I wonder how many photons per meter squared reach the earth from say... Sirius. If I know that I could figure out the photon density at the surface of that star.
radiotech
Wed Dec 01 2010, 07:01AM
Suppose you had a box containing a coil of fibre optic cable
with the start and end coming out of a hole on one side with
about 1 meter of flexible cable coming out to a light and a detector.
Could you know somehow if someone turned the box upside down,
i.e. the light now goes counterclockwise instead of clockwise around
the coil?
Adam Munich
Wed Dec 01 2010, 11:17AM
What?
Renesis
Wed Dec 01 2010, 02:51PM
radiotech wrote ...
the coil?
You mean wether you could measure the orientation of the box by measuring the light coming out of the fibre?
Hmm, if you rotated the box around the axis of the coil so fast that the optic fibres inside were moving close to the speed of light, would light still keep hitting the detector? And would the Doppler effect turn the light into say, radio waves?
radiotech
Wed Dec 01 2010, 05:36PM
Many things are handed, that is tend to go to the left
or right. so could the lightwave have attracted an attribute
that could be identified. Another way of thinking could be
considering if there is some general curl direction to the
universe that affects this experiment.
Light is bent by gravity. Could a giant light spiral
therefore push back on gravity?
Thu Dec 02 2010, 10:52AM
I'd go for Faraday rotation in the Earth's magnetic field.
